Rumford Fireplace Help
Old 11-03-2009, 11:37 PM   #1
DI Restoration's Avatar
Trade: Restoration
Hello Guys,
I have been a long time lurker. Great information here.
Well, a customer of my has requested a Rumford fireplace to replace the metal firebox that is in the home now. I am not a Mason but was wondering if you guys could point me in the right dirrection to getting this built for him?
Any help would be great!
Doug
DI Restoration is offline
Old 11-04-2009, 01:34 AM   #2
lukachuki's Avatar
Re: Rumford Fireplace Help
Originally Posted by DI Restoration View Post
Hello Guys,
Doug
rumford.com great great resource!
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln-
Less with the jaw more with the paw!
lukachuki is online now
Old 11-04-2009, 06:06 PM   #3
6stringmason's Avatar
Trade: masonry
How about get a hold of your mason and have him do it?
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is online now
Old 11-05-2009, 11:58 AM   #4
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Six's advice is sound---you will need a GOOD mason to look at the existing situation and determine first the feasability, and second the scale of the job.
I don't think that it will be a simple job from where I'm sitting, but then again, it just might be.
Darn, spell check won't work,
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 11-06-2009, 09:06 AM   #5
AmeliaP's Avatar
Trade: Masonry
We have done them. You need a good Mason.
AmeliaP is offline
Old 11-06-2009, 06:24 PM   #6
72chevy4x4's Avatar
you'll need a lot more height than a typcial firebox and a lot less depth-guess it's possible to cut out what's already there, but not sure you'll would be able to have enough room to create the upper chamber above the damper. The key isn't just a 'good' mason, but one who has actually built these types of fireboxes. I have heard of a typical style being retrofitted-that is angling the sides more and decreasing the depth of the back wall (leaving the height alone)-a compromise of sorts.
72chevy4x4 is offline
Old 11-07-2009, 08:49 AM   #7
Trade: Restoration
Thanks for the replies. I have had my Mason look at it and he has recommended using a Firerock prefab due to time restrictions.
Old 11-26-2009, 11:54 AM   #8
Trade: Restoration
Update,
We went with a Firerock prefabbed unit for the project. I will post pictures after the job is completed.
Old 12-25-2009, 02:47 AM   #9
masonryworks's Avatar
Trade: Mason Contractor
I built one a couple of years ago, and you definitely need a good mason, I didn't have the metal insert, so I built it using fire brick with 6 inch block as a structure around the fire brick, then did natural stone for the finishing touch. Built an ash drop in the bottom, then set the pre-manufactured clay throat on then the damper and its a basic chimney from there up. You need to order a kit that has all the details from Rumford, it will cost you around a thousand dollars just for that.
-masonrywortools.com
masonryworks is offline
Heating new Family Room w/ gas fireplace? Slowtrawl HVAC 56 06-20-2010 06:50 AM
Fireplace quote atmasonry Masonry 4 08-25-2009 09:14 AM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Masonry chimney on new EPA fireplace? GregWCIL Masonry 8 10-28-2008 09:51 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
