Rubber Expansion Joint?
Old 10-25-2008, 02:19 PM   #1
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
Hi all I need some help . I have some concrete flat work and some curbing that needs expansion joint . I want to cut the joint and add Rubber sealer that matches the concrete color but i don't know what the stuff is called Its like a silicon and come in large tubs. Any one have a name for me
wellbuilthome is offline
Old 10-25-2008, 02:30 PM   #2
Tscarborough's Avatar
Re: Rubber Expansion Joint?
Sonneborne SL1 is one, there are many. I would suggest a polyurethane not a silicone, though.
Tscarborough is online now
Old 10-25-2008, 04:43 PM   #3
Kgmz's Avatar
Read my post here. And as mentioned before if you use another brand, make sure it is a polyurethane
http://www.contractortalk.com/f83/expansion-joint-repair-41561/
http://www.sikaconstruction.com/fs-c...lex1CSL-us.pdf
Kgmz is offline
Old 10-25-2008, 05:22 PM   #4
Ivinni's Avatar
Trade: High Rise Caulk and Insulation
Why would you use polyu and not silicone?
its not going to get better with straps, or new footings or even aroma therapy.
Ivinni is offline
Old 10-25-2008, 09:38 PM   #5
Thanks guy your the best . I have some joint filler coming in the mail
Butt Joint problems AARC Drywall Drywall 10 09-14-2008 03:40 PM
Expansion joint repair mdshunk Concrete & Paving 5 08-11-2008 11:16 AM
Expansion joint material ejleonard Masonry 1 07-02-2008 10:40 PM
Rubber roof codes... frisco84 Roofing 3 09-15-2007 12:44 AM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
