Retainer Stem Wall
Old 08-20-2008, 11:16 PM   #1
tkle's Avatar
Retainer Stem Wall
Engineer is calling for a 2' concrete stem wall 8" wide at the base of an 8' cmu retaining wall. We generally use 12's at the bottom as per most details. Is there a reason for the stem wall?
tkle is offline
Old 08-20-2008, 11:20 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Retainer Stem Wall
Soil conditions, Frost conditions, to lock it in so it doesn't have the leaning effect in short order.
Chris
Chris Johnson is offline
Old 08-21-2008, 09:07 AM   #3
concretemasonry's Avatar
Trade: Masonry consultant
You did not get paid for designing it, so just build according to the plans and specs. - We can't see it from where we are and don't know the conditions.
Retaining walls (especially rigid walls) are probably the most difficult thing to engineer, get built right and last as long as everyone expects. It sounds a little strange, but I can't really understand
I am sure you do not want the liability for the design, especially since you probably do not have insurance coverage the designer has to carry.
Dick
concretemasonry is offline
Old 08-21-2008, 10:34 PM   #4
tkle's Avatar
I ain't changing nothing without an engineer stamp. I've only seen this detail a few times and wondered about it. I have considered consulting the engineer but would like to know a few reasons behind the design first.
tkle is offline
Old 08-21-2008, 10:39 PM   #5
Tscarborough's Avatar
Since he has designed an 8' retaining wall built with CMU, it is probably based upon ignorance, but as stated, that ain't your problem.
Tscarborough is offline
Old 08-21-2008, 11:37 PM   #6
tkle's Avatar
I hear you about the ignorance. However my clients problems are always my problem
tkle is offline
Old 08-21-2008, 11:41 PM   #7
I agree, and always argue for SRW for retaining walls, even though my primary business is CMU.
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 05:57 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
Mono or stem wall Fl. flood plain Framer33884 Masonry 2 04-08-2006 05:31 PM
Mono or Stem Wall Framer33884 General Discussion 0 04-01-2006 02:03 AM
