Residential Limestone Cladding
Couple years ago I came across a company out of Texas, I think, that sold a limestone cladding system. It used either a stainless or galvanized vertical hat channel screwed to the framing. The limestone was installed as a running bond with mortared joints. The limestone was screwed to the channel using metal biscuits, picture a woodworking biscuit with a hole in the middle, that were set into slots cut in the tops and bottoms of the stones.
The stones were smooth face about 24" x12" x1.5" with pillow edge detail. Anybody familiar with this system or the company that sells it? I've been searching for a few days with no luck. Thanks, verm Last edited by Vermaraj; 05-13-2008 at 12:44 PM. |
Trade: Masonry
Re: Residential Limestone Cladding
Did a HUGE house in limestone, many years ago. Had Petrillo out of NYC do the fab work. Most blocks were 16"X32"X4"
Use ONLY stainless and a type O mortar. I think were were mixing 6 sand to 1 lime and 1 white portland. DO NOT use regular portland. |
Trade: Masonry
Re: Residential Limestone Cladding |
#4 | |
Re: Residential Limestone CladdingQuote:
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
Trade: Masonry
The house we did was similar in scope to this place, without the grand entrance. It did however have a lot of detail as well as the medalians.
CJkarl,
I've been looking at some of your work in the picture posts. Excellent work! Do you make it down to Fairfield County? This is similar to what I was thinking of: http://www.americanlimestone.com/res...dvantages.php4 The other company had more edge detail options. |
#7 | |
Trade: Masonry
I've been offered double my rate to work down there, but I refuse to make that drive every day. 95 from New Haven south is a NIGHTMARE! As far as that limestone cladding, I'm leary of the longevity of systems like that. Too many things to go wrong down the road. I want the stuff I build to last hundreds if not thousands of years. Not 20. |
Vermaraj and CJKarl, that is not a proprietary system, it is a standard detail for stone cladding. So long as you use SS, it should last for 100's of years.
It ain't Rocket Science unless you are building rockets. |
Trade: masonry
Its precast not limestone, but Arriscraft makes a system similar to what you are talking about. We are installing it on the soffit of a few large entrances of a casino. Pretty nice looking material.
Two links: http://www.arriscraft.com/pdfs/ThinBedBrochureB.pdf http://www.arriscraft.com/aci-menu/index.html?corp <---not sure where this will take you, but click it and go to whats new and click on Thin Clad Renaissance. |
Yeah, like I said, that is SOP for masonry cladding. Just make sure that all metal is SS, and it will last for a very long time.
#11 | |
#12 | |
Do you know if the individual clips are available from a supply house? |
It is very expensive. I sell various sorts of anchors and ties, but doubt anyone would stock parts and pieces of a proprietary system.
I found the company that makes the aluminum extrusions:
http://www.gridworxwalls.com/ Do you have any idea what the components go for? The aluminum extrusions themselves can't be that expensive. The system stamp on the other hand ? |
I have access to that sysem but no interest in providing it. It looks to be OK, just a modifed, proprietary implementation of the standard method of stone cladding. If you like, I will get some pricing for you, but I reiterate: I will not sell the product.
#16 | |
Also the aluminum extrusions with stainless lags is concerning. Could lead to galvanic corrosion that ultimately undermines the wall. Maybe they have thought this through since it is being used extensively in the NYC area which is a very corrosive environment? What else concerns you about a system like this? |
Any proprietary system carries a legal liability. This is one of the reasons they are so expensive. As a supplier, I do not feel that it is my duty to indemnify the customer, architect, owner, or manufacturer simply by acting as distributor. The value I add is service in the supply of the product, not the design and manufacture, installation, or specification.
In the case of this particular product, my question would always be: Why not use SS eared anchors, or pins? It works, it is easy and it is cheaper. If the application does not call for a full bed mortar joint, then thinset or even construction adhesives will suffice. I did not read their literature deep enough to see what their answer for the galvanic corrosion question is, but I am sure that they address it in some way.
| Painting Limestone Rails & Spindles | plazaman | Painting & Finish Work | 6 | 07-01-2011 05:58 AM |
| Moving on from residential to commercial | no1bldr | Commercial Construction | 6 | 04-30-2008 06:05 AM |
| Limestone Tread: Sort of...crumbling? | Tommy C | Masonry | 15 | 04-03-2008 03:43 PM |
| Seagrass Limestone in Shower? | Remodelboy | Ceramic & Stone Tile | 5 | 02-20-2008 12:02 PM |
| Need Advice for New Residential Contractor in Florida | DoubleJ | Business | 6 | 05-19-2007 11:37 AM |
