Resetting Concrete Foundation Block
Old 10-30-2013, 04:52 PM   #1
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,104
I'm not a mason and have limited masonry experience, so I apologize for this rookie question. What is the proper way to reset a concrete block in a foundation wall? By this, I mean the mortar supporting a few top course blocks has eroded and these blocks aren't bearing weight. This was my solution. Feel free to have a laugh at the hackery. (this is my home, I would not be improvising this kind of thing for a client)
dielectricunion is offline
Old 10-30-2013, 05:12 PM   #2
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,426
Re: Resetting Concrete Foundation Block
This is not really an answer... I'm not a mason either... but can't you grout it with some dry pack.....?
sorta like a stemwall mistake....
but there may be some better technique for block.......
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 10-30-2013, 05:27 PM   #3
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
I typically would do the repair like you are doing....ahhh, maybe a little more precise with the mortar joints.
Do you have wedges on the outside too? You should.
I like the plastic carpenter shims, slide them out when the mortar sets up enough to support the block, joint off everything nice and neat.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 10-30-2013, 06:24 PM   #4
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 72
I do pretty much the same thing, soak the shims overnight first though, they are easier to pull out that way.
NYCB is offline
Old 10-30-2013, 06:52 PM   #5
hack of all trades
Trade: Electrician
I should have thought to put something on the shims as a releaser because I broke them off and theyre wedged in. I shimmed tight from both sides and forced as much mortar (just used quickcrete type s) in to the joints as I could. The wood will probably wick more moisture into the joint and cause it to fail. Any other repairs I'll use composite and remove them. Thanks for the advice!
Old 10-31-2013, 06:47 AM   #6
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Yes a typical way of doing it. you could probably chisel the wedges out, or punch them in
www.dominionmasonry.ca
dom-mas is offline
Old 10-31-2013, 07:41 AM   #7
hack of all trades
Trade: Electrician
I'll send a few termites in to consume them
Old 11-01-2013, 08:04 AM   #8
CJKarl's Avatar
Trade: Masonry
I would not worry about the wood in this situation.
CJKarl is offline
Old 11-01-2013, 11:39 AM   #9
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I would if they are outside
dom-mas is offline
Concrete Slab vs Block vs Pier / Post Foundations carpenj4 Construction 4 09-23-2013 04:41 AM
Concrete Block Wall Leaking confused1 Masonry 5 10-10-2012 06:25 AM
Anything to improve exterior aesthetics of concrete block? Python49 Painting & Finish Work 14 07-12-2011 11:32 PM
block foundation addition kubie Masonry 13 03-14-2010 12:05 AM
Best way to shim a block foundation forsmant Framing 22 02-01-2010 05:21 PM
