Trade: contractor
Repointing Brick
i have the opportunity to re-point an old brick deck if I want. Still thinking about it. I am NOT a mason ... i have enough masonry experience though - im confident with some advice i can handle it.
Mortar joints are to be repointed i've set flagstone before - but NOT brick i can't even remember the right mix, now that I think about it. I think I've done 3:1 sand/cement. anyways - i could go on --- but looking for *right* advice on the following: what type of mix to use (contents, ratios) just any general advice - as the posts come in, maybe ill get more focused questions thanks DD |
Re: Repointing Brick
3 to 1's about right.I like about 2.5 to 1.Half a shovel of lime will help it go through a grout bag.Dig out any lose joints and reset any lose brick.Not much to it.What type of brick?Are the joints washed or tooled?Is the grout course or smooth like tile grout?
#3 | |
Trade: contractor
Re: Repointing BrickQuote:
the rest i'll grind down about 1/2 inch not sure what you mean by washed or tooled (im assuming washed means it was dry grout mix moistened after being placed - tooled being wet grout???) it's coarse ... not smooth how come some grout turns out cement color - while other grout has a yellowish/sandy color to it |
Washed or tooled refers to how the joint is finished.Trying to match the existing grout.The grout can be troweled into the joints using a dryer mix or put in with a grout bag using a wetter mix.It is then cut flush and sponged over similar to tile smoothing it out and wiping the paste off leaving the sand more exposed or tooled with a tuck pointer or a rounded jointer giving it more of a slick look leaving the paste on top similar to troweled concrete.The difference in color may be due to the grout being improperly mixed in the first place or from the top of the grout(the paste)deteriorating due to freeze thaw action.Different methods are used where freeze/thaw is a major problem.
Even though this is brick, I hesitate to call it tuckpointing. You are doing the same thing, but on a horizontal plane. All of the stresses and requirements are different for grouting (flatwork) than for tuckpointing (vertical).
Generally, I recommend a soft mortar for tuckpointing to increase bond strength and reduce shrinkage. For flatwork, I can see using a stronger mix, and including an entraining agent. A good mix would be 1 part portland, 1/2 part Type SA lime, and 2-1/2 parts good sharp sand by volume of cementious materials. The depth of the replacement joint should be a minimum of the width, and deeper is better, though not required. My only question would be if the deck served as a ceilinig or is it on the ground? |
Trade: contractor
ok -
what's the purpose of having lime into the mix |
Lime does 3 things:
First, it delays the set of the mortar. One of the major differences between concrete and mortar is it's pot life, and the ability to have it "set" and then shake it up and reuse it, i.e. "tempering". The second thing it does is make the mortar stickier and more "creamy". It does this by reducing the required amount of water for a given amount of ingredients and by entraining micro-capsules of air. The third effect is less shrinkage cracks, and a process called "autogenous healing", which is a characteristic of lime based mortars and stuccos. |
Trade: contractor
i think my only concern is matching the existing grout that he doesn't want removed ...
im picky and tedious enough to do a thorough job it's just blending everything in tscar - sorry - no not a ceiling - a patio |
That is good, because if it were, my only advice would be to flee.
The only way you will be able to match exisiting grout is to rub so much dirt on both that it doesn't matter.
Another question is why the grout is deteriorating in the first place?The entrained air gives the moisture a place to expand when it freezes without popping the mortar.Correct me if I'm wrong Tsc.I'm not an expert on cold weather.
Trade: contractor
Tkle -
not sure honestly ... there's a couple hairline cracks. I think the brick is set on a concrete sub-base and there is definitely evidence of heaving. I'm not to fix that - just purely making cosmetic touch ups here - and HO's aware of that |
You are pissing into the wind, then, and should tell the HO that.
Trade: contractor
i guess he'd have to have the entire deck redone to have something that wasn't just going to come back i guess ...
it's not abundant with cracks ... about 3 major areas (the brick is a good 1/4" higher than the others that these points) i think if it's coming from heaving -- he needs to take the concrete base out ... essentially start over |
Segmental Concrete Pavers are his friend.
#16 | |
I dunno, the arbor on that thing doesn't look too precise to me......
It ain't Rocket Science unless you are building rockets. |
#18 | |
Good eyes! I guess that is why they are Precisiondiamondinc.com they should change their name to unbelievablevibrationdiamondinc.com
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
#19 | |
Trade: contractor
I learned a HELLUVA lesson on this job .... ![]() STAY IN YOUR BOX, guys. Stay in your box. Especially now, with the economy .... be careful how you appraoch "diversifying" your services. Not a whole lotta jobs to pick from now ... so the ones you get, gotta be profitable
Thanks in advance!!!
#20 |
Trade: Gee Bees Construction All fields of Construction from remodeling to roofing Specializing in Waterpro
Deep cutting the joints with a diamond wheel or an arbortech is a key step in the process. We have done entire buildings in Manhattan. Your motar mix should be up to par and consistent. Pressure washing all areas to be pointed is a critical step in the process. It allow for better adhesion. Me an my customer prefer tooled joints. It gives the building a cleaner look.
| Thin Brick, VS Regular Brick | Project53 | Construction | 25 | 03-11-2010 03:13 PM |
| Braking metal for a brick exterior? | Luke's Dad | Windows, Siding and Doors | 8 | 01-07-2007 06:59 AM |
| wire behind brick | hurricaneflyer | Electrical | 7 | 11-13-2006 08:03 PM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
| red brick has developed a white coating | wbsbadboy | Masonry | 4 | 02-28-2006 09:33 PM |
