Replacement Of Brick W/ A Gray Glaze/morter Spread On Face Of It
Old 11-26-2017, 08:54 AM   #1
asnigro's Avatar
Trade: GENERAL
Rewards Points: 2
I dont come across bricks of this nature very often, what are the terms I should be using in contacting brick yards/masons for replacement? I'll be attempting to re-use as many of the bricks as possible, then finding the next best thing for the rest.
Is the gray a "glazing"? I cant believe I'll find exact bricks, so color matching the underlying brick (which is a peach-ish/orange in "king" size 9 5/8 long), then re-creating the glaze I'd assume is best approach.
Thanks.
Replacement of Brick w/ a gray glaze/morter spread on face of it-brice-face-multiple-01.jpg   Replacement of Brick w/ a gray glaze/morter spread on face of it-brick-close-up-glaze-01.jpg   Replacement of Brick w/ a gray glaze/morter spread on face of it-brick-back-side-glaze.jpg   Replacement of Brick w/ a gray glaze/morter spread on face of it-single-brick-close-up.jpg
asnigro is offline
Old 11-26-2017, 11:27 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 9,132
Re: Replacement Of Brick W/ A Gray Glaze/morter Spread On Face Of It
If you have access to the back side of numerous brick,you may get lucky and find a company name stamped on the back. If not,good luck.
fjn is offline
Old 11-26-2017, 02:33 PM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,798
Looks like a cheap (garbage) brick to me. From the pictures it does not look like they have the name of the manufacturer on the back like some do
Best bet is to take a couple to the brick yard and see what they have available
Windycity is online now
Old 11-26-2017, 07:05 PM   #4
brickhook's Avatar
Trade: masonry
Rewards Points: 7,566
Call your local brick company, and have them send out their salesman. He will be able to identify the brick for you.
brickhook is offline
Old 11-27-2017, 07:50 AM   #5
Tscarborough's Avatar
Rewards Points: 1,406
Don't call your local brickyard, you can't match brick on the phone or very well even with photos and they probably won't send a salesman to match a couple hundred (or thousand) brick. Take some to the brickyard. That looks like a dipped brick, find one that has the same basic color and then make a slurry with Portland, lime and water and dip them.
Tscarborough is offline
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
Fouthgeneration (11-28-2017), jomama (11-27-2017)
Cracked Brick Kneewall Planter Moishe3rd Masonry 4 04-28-2014 07:38 PM
Quick Plank Replacement Tip PrecisionFloors Flooring 5 05-23-2013 07:20 PM
New home cost estimator spread sheet? Joasis Technology 1 12-30-2012 12:29 PM
removing brick Yersmay Masonry 27 12-24-2011 10:46 PM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 06:19 PM
