Removing Stucco/cement From Interior Brick Wall - Page 2 - Masonry - Contractor Talk
Old 01-27-2018, 11:45 AM   #21
Renaissance Man
superseal's Avatar
Rewards Points: 5,474
Re: Removing Stucco/cement From Interior Brick Wall
As well, I know for a fact I could remove and clean that much sq ft easily in a weeks time and would gladly remove 6K from your pocket.
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
kirkdc (02-07-2018), RookiePlumber (01-27-2018)
Old 01-27-2018, 12:25 PM   #22
Renaissance Man
superseal's Avatar
Originally Posted by stuart45 View Post
What's Barn Dashing S/S?
Textbook barndashing is generally the pointing being extended well beyond the joint region. It can also be refereed to in plaster and render work in which sporadic areas of brick and stone are exposed.
https://www.cumby.com/news/historic-...-namur-mansion
http://www.mathieu-mitchell-builders...ar-re-pointing
JBM (01-28-2018), stuart45 (01-27-2018)
Old 01-28-2018, 06:12 AM   #23
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,667
Cover the floor with some 10 Mil poly , cut in the second bed joint a drip edge/ gutter apron, install a Style K gutter with a pump to mud tank. proceed to powerwash...
Sponges and rubbing stones would faster/cheaper then the Bosch chewing up a bunch of soft bricks
For under 5K just lay another wythe of 2" bed bricks, saw up some commons, use lots of mesh ties.. Hire A BOOT or do it yourself so it looks ROUGH.
About the same $$, maybe more time, Thin brick after a scratch coat of plaster and mesh?
What were you planning to do when you mop the floor? move out?
maybe some nail on faux bricks from lowes https://www.lowes.com/pd/47-75-in-x-...-Panel/1015475
Fouthgeneration is offline
Old 01-28-2018, 09:54 AM   #24
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,046
Thanks for the links S/S. There's a lot of stone buildings where I live, but I've not seen this method used here. Most of the repointing done on old stonework now is lime mortar pointed flush and wacked with the Churn brush.
stuart45 is online now
Old 01-28-2018, 08:46 PM   #25
JBM's Avatar
Trade: Masonry
Rewards Points: 5,016
I kinda agree with 4th gen, just lay a course in front of it, would take a guy a day or so and would come out however you want it, clean, rough, w/e
JBM is offline
The Following 2 Users Say Thank You to JBM For This Useful Post:
Fouthgeneration (02-01-2018), RookiePlumber (01-31-2018)
Old 01-29-2018, 11:34 PM   #26
Kscherbain's Avatar
I say start with a 2x2 area. See if you dig the action. Could be a way to save money. If it sucks, hire someone. Not for 6gs though, couple quotes will help that
Kscherbain is offline
The Following User Says Thank You to Kscherbain For This Useful Post:
Old 01-31-2018, 07:02 PM   #27
RookiePlumber's Avatar
Trade: Plumbing
Rewards Points: 264
Went at the wall with a demo hammer today. Some parts fall off in decent size pieces. Others are on there good. They are sort of coming off with a few passes. As superseal suggested going slow is helping knocking those layers off.
I started spraying the wall with a 1 gallon pump sprayer and the render material literally drinks the water. Barely any runoff. The water is really helping with dust control. I think the water is making removal with a demo hammer easier. The material breaking off are like bits of sand and not dust.
Sharpening my chisel bit is helping.
The layer that is left over is going to be a pain to remove. My initial idea of using a concrete surface grinder probably isnít going to work as many of you have advised me.
I going gently use a knotted wire cup wheel attached to a grinder. If I wet the hell out of small sections Iím hoping the remaining ďsmearĒ will come off like bits of sand and not create a dust storm.
Getting pneumatic chisels is still an option. Iím still way under budget.
Talked to a dry ice blaster firm today. The guy walked me through the process and told me my neighbors wouldnít be knocking on my door to complain, theyíd call the cops. The noise is allegedly as loud as a rock concert.
RookiePlumber is online now
Old 02-03-2018, 04:55 PM   #28
Trade: Plumbing
Rewards Points: 264
Originally Posted by superseal;l
when I say pneumatic tools, I mean air tools then can be dialed down to a very low bpm which can literately dance the render off the surface with extremely controlled results which preserves the brick. Very low dust as well.
On the last 1/4 of the wall I went really slow with the demo hammer and was able to get a much cleaner brick surface. I should have listened to this advice from the beginning.
To remove the render off the rest of the wall Iíll get a brick rub and a sharp hand chisel.
Is this black stuff mold? How can I remove it indoors? I cannot hose off any chemicals indoors.
Thx
Old 02-03-2018, 06:47 PM   #29
Renaissance Man
superseal's Avatar
Thx
Take some Mold Armor to it and see if it removes it.
Looking good rookie!
Removing stucco/cement from interior brick wall-mold-armor-paint-thinner-solvents-cleaners-fg523-64_1000.jpg
The Following User Says Thank You to superseal For This Useful Post:
RookiePlumber (02-05-2018)
Old 02-07-2018, 05:17 PM   #30
Trade: Plumbing
Rewards Points: 264
Hired a kid on Craigslist to scrap and wire brush the brick for 2 days. Came out ok.
I still need to get the white marks off the brick. Using vinegar for that.
And Iíll it it with mold armor to get off the black stuff. Though I think that stuff is on there permanently. The mold has been behind the render for decades.
Old 02-07-2018, 06:22 PM   #31
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
May the Force be with you.
kirkdc is offline
The Following User Says Thank You to kirkdc For This Useful Post:
RookiePlumber (03-07-2018)
Old 02-07-2018, 10:33 PM   #32
Trade: Masonry
Smoke blacken brick? Check local fire department blotter for fire at that address, any digitized local old newspapers for same.....
Many a interior wall in the big cities were built out of used brick, many culled from the rubble of a burnt down building. Arguably, reburnt used brick can be stronger then single fired common back up bricks....
Even in an un burnt demoed building a few % of the brick were always stained by their position in chimneys present for pot iron stoves and ovens. and of course the whole building furnace/boiler chimney bricks.
I'd use muratic acid diluted 4-1 with sponge on the newer/gray mortar patches to burn out the Portland cement leaving just the sand on the surface... wear eye, lung and hand protection, roll a "gutter" cuff to protect your forearms, some lime spread on the catchment plastic will neutralize any fallen acid.
Common sense would have you sealing the soft brick and mortar, the low strength mortar and softer bricks doesn't form a lasting cleanable surface.
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Removing wall panels from GAP Store in mall. ECinc Commercial Construction 3 02-17-2014 07:04 PM
Dead wall sconce box. bob_cntrctr Electrical 5 03-09-2013 05:50 PM
Couple questions on Double Stud Wall duburban Green Building 10 01-06-2012 08:46 PM
Removing Exterior Load Bearing Wall thahn1608 Framing 2 09-02-2011 05:09 PM
removing old drain/clean out at foundation wall brianford Plumbing 7 04-15-2011 03:46 PM
