Removing Old Adhesive From Brick???
Old 02-16-2012, 10:35 PM   #1
232323's Avatar
Trade: remodeling contractor
Rewards Points: 154
Is there any way to remove old adhesive from brick without damaging the brick? The adhesive dates back about 50 years. It was used to attach Masonite type panels over the brick. There's hundreds of square feet involved so we're looking for a less labor intensive method of removal. The brick is sound....Thanks for any suggestions
232323 is offline
Old 02-16-2012, 11:43 PM   #2
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Re: Removing Old Adhesive From Brick???
Mastic?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 02-17-2012, 07:18 AM   #3
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,352
Sandblasting.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 02-17-2012, 07:26 AM   #4
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Is there a texture to the brick? If no a razor would be the best but slowest method. Sandblasting would be the quickest but most damaging method. I would try to find out what this stuff dissolves in. Then try to dissolve it/scrape it off it a inconspicuous area. Unfortunately there is no easy answer.
dom-mas is offline
Old 02-17-2012, 07:27 AM   #5
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I guess the other question is are you trying to make the brick look good or just get a smooth surface to apply another siding?
dom-mas is offline
Old 02-17-2012, 08:13 AM   #6
Tscarborough's Avatar
Rewards Points: 1,402
Sand blasting if it is interior, chemical removal if exterior.
Tscarborough is offline
Old 02-17-2012, 08:21 AM   #7
General Contractor
greg24k's Avatar
Rewards Points: 7,236
Try this company out, you should find what you looking for Prosoco.COM
greg24k is offline
232323 (02-17-2012)
Old 02-17-2012, 08:51 AM   #8
232323's Avatar
Rewards Points: 154
The brick is reasonably smooth and this is an exterior application. We would be trying to restore this area to the original look to match the existing brick that wasn't defaced. This is a historic building that up for sale, so we can't remove the product yet for inspection, but this is a key part of the renovation plan. The mastic that was commonly used here during that era was a black, crusty looking adhesive (sometimes called Marsh mastic) that was trowel on. I'm assuming thats what we would be dealing with. I did read about about sandblasting with corn fines...any thoughts?
232323 is offline
Old 02-17-2012, 08:58 AM   #9
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
yes, that can work, as can rubber pellets. Make sure whoever your dealing with has experience in masonry restoration blasting and is willing to do a test area first. At all costs, do not use sand as it will take away the first 1/32" of the brick or more and the brick will be garbage after that.
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
fjn (02-18-2012)
Old 02-17-2012, 09:01 AM   #10
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
if the mastic is hard and brittle I've had success using a small chisel and chiseling it off. If you try this method, make sure to use a light blow, if the adhesive is stuck really well to the brick it will take the face off. I use a chisel then finish with a razor blade for old caulking all the time, but at hundreds of square feet that would be time consuming.
dom-mas is offline
Old 02-17-2012, 09:27 AM   #11
lukachuki's Avatar
Rewards Points: 1,002
I'd call prosoco and ask what they would recommend and then try a small test patch and then go from there.
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 02-17-2012, 09:54 AM   #12
232323's Avatar
Rewards Points: 154
I just called them. They will send samples of various products that should work. Thanks everyone for the helpful tips.
232323 is offline
Old 02-17-2012, 11:56 AM   #13
amertrash's Avatar
Trade: Brick/Tile/Stone/Landscaping Provider
You could try calling your local rep for Diedrich Technologies( http://www.diedrichtechnologies.com/) as well too, they make a large line of products specifically for cleaning/restoration stone/brick.
amertrash is offline
Old 02-17-2012, 04:10 PM   #14
JBM's Avatar
Trade: Masonry
Rewards Points: 4,114
Goof off?
JBM is offline
Old 02-17-2012, 08:54 PM   #15
fjn's Avatar
Trade: mason
Rewards Points: 8,818
232323 That 50 yr.old mastic you are up against probably is asbestos laden,i would bet a dollar to a donut. Be careful.
fjn is offline
Old 02-17-2012, 10:12 PM   #16
MAULEMALL's Avatar
Trade: GENERAL CONSTRUCTION
Rewards Points: 98
asbestos laden
MAULEMALL is offline
The Following User Says Thank You to MAULEMALL For This Useful Post:
MALCO.New.York (02-18-2012)
Old 02-17-2012, 10:13 PM   #17
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Shouldnt this be in the sandblasting forum?
ohiohomedoctor is offline
Old 02-18-2012, 06:04 PM   #18
stacker's Avatar
Trade: masonry
Rewards Points: 542
not if it is a question on brick.sorry im a smart azz,but it has to do with masonry and this is a masonry forum.
anyway,i agree sandblasting with sand would damage the face of the brick and make it more suseptable to slacking.i have heard of using ground walnut shells for sandblasting,this might work also.
stacker is offline
Old 02-18-2012, 06:14 PM   #19
fjn's Avatar
Trade: mason
I beleive the most gentle method of abrasive blasting is a method called ARMEX. It uses frozen baking soda. On soft salmon molded brick i saw a test panel. It was rejected as still to harsh and intrusive. I would not have approved of its use if i were the building owner. Bottom line,any abrasive method is still abrasive.
fjn is offline
Old 02-18-2012, 06:50 PM   #20
blastaway's Avatar
Trade: Sand & Soda Blasting
Armex is baking soda that is blasted through a soda blaster at different pressures. It comes in different particle sizes and is a 2.5 hardness on the Mohs hardness scale where sand is a 6.5. Baking soda can be done wet or dry.
It is generally used for removing dirt, paint, etc on soft surfaces i.e., brick, aluminum, fiberglass, etc.
Chris Bair
ESCA Blast
chris@escablast.com
www.escablast.com
blastaway is offline
removing brick Yersmay Masonry 27 12-24-2011 10:46 PM
Removing sheet linoleum adhesive Old Crow Tiling 14 03-14-2011 10:45 PM
removing cutback adhesive for acid staining rservices Flooring 3 02-12-2011 07:05 AM
Removing excess mortar from brick RadRemod Masonry 22 01-03-2011 02:10 PM
Removing Carpet Adhesive w/ a Pressure Washer dprimc Flooring 10 08-29-2010 03:05 PM
