A Reinforcing Question
If you are going to reinforce a 3/4" to 1" slab of mortar, so it don't crack, that will actually be underwater a lot of the time what is the best material to use. Gots to be rustproof. Thanks
Re: A Reinforcing Question
I could be wrong, - - but I don't think anything's going to stop it from cracking, - - how big is it and what are you using it for??, - - What's it going on top of??
He wants to coat a PVC pond liner to protect the liner, but I don't think it is a good idea. I have always laid a cushion of pea gravel.
Trade: Masonry
no i may be wrng on spellling bee , but ill say it as it sounds maybe someone will have right spelling ,,,, but ive seen and worked along side a pool crew doing GA-NITE,, its a spray on Crete,, wrks grt.
Gunite. You are making the effort, Dik, S!
Trade: Masonry
thank you Tscar,, not in that field so did`nt pay attention to spelling ,,only chit/chatting with pool workers did i learn the name and process of it .
v-16 & cement
......Less with the jaw & More with the paw..... |
Trade: Masonry
Re: A Reinforcing Question |
yup
Trade: Masonry
thought so lol i helped my old bosses brother out ,, we mixed it in a barrel mixer even lol,, type 2 and that V-16 ,.. troweled on and bamm that was 8 yrs ago , no problem,,,
vermiculite? don't that stuff pose a heath concern
No. One particular mine was contaminated, but it has ceased production.
Trade: Masonry consultant
You won't find 3/4" structural gunite and you need reinforcement.
Vermiculite concrete is very weak and is very sensitive to mixing and pumping if pumped/blown. Not for amateurs. You need something like steel (no fibers) to give you structural tensile strength. With vermiculite you also run into freeze/thaw durability problems.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
What you can do is lay your gravel bed, then stack rock up the sides, even using faux stone. This is a concrete pond, but I loose stacked the rock around edges for habitat and looks.
#15 | |
Re: A Reinforcing QuestionQuote:
verm & cement is a a flexible pourous substrate. freeze famage occurs when verm "winters over" with less than a foot of H20 on top. it is the ideal substrate for a liner, even it it did suffer freeze thaw damage, you still have a "shaped" & non abrasive subbase. it is merely a "prepared bottom" material & not too hot structurally. no steel is used with it. I just reread original post 3/4" slab just isn't happening. you would be better off trowel "dead sand" ray
#16 | |
Trade: Masonry
wow 6inches....
overdig.......
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Question about bidding vinyl wallcovering | kanadaeh | Painting & Finish Work | 9 | 02-19-2009 05:29 PM |
| Basement Window Question | gregt848 | Windows, Siding and Doors | 9 | 07-26-2006 06:29 PM |
