Rebuild Of 200 Yr,octagonal Chimney Stacks.
Old 01-02-2018, 06:44 PM   #1
fjn's Avatar
Trade: mason
Rewards Points: 9,220
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
JBM (01-06-2018), Metro M & L (01-02-2018)
Old 01-03-2018, 04:37 AM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 10,386
Re: Rebuild Of 200 Yr,octagonal Chimney Stacks.
Is that something you would do Fred?
SmallTownGuy is offline
Old 01-03-2018, 11:22 AM   #3
fjn's Avatar
Trade: mason
In regards to the jack lines and jigs ? Would probably do it at tad different. Years ago,saw a sliding template,I think was made in either Italy or Spain. It was the catalyst for me to weld up some accouterments for my Bon -Tool corner leads,with them I'd follow a Plexiglas template.I also years ago was able to use those same pieces to lay curved walls as easily as laying to a line.
As far as the pointing goes,a couple of years ago,(partially as a result of JBM's post) I bought a Quickpoint mortar gun,would never look back. The advantages of that gun are better than I ever dream pt of.
As far as the wood striking,the jury is still out on that one.
fjn is offline
JBM (01-06-2018)
Old 01-03-2018, 05:02 PM   #4
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 612
I think he was asking if you took similar jobs???
I would probably do it like they did. The upper template and jack line come naturally to me as a stone mason. I would like to see your corner pole setup. I have some 2x2 aluminum tubing that I bought in 20' lengths from the metal supply and cut into various sizes. I rarely use them though. I don't have any fittings for them and couldn't be sure that the ones you can buy would fit. I just use clamps for plumbing them, etc.
Their "grout" caulk gun looked super slow. I would be 2-3 times as fast with a grout bag. I've never used a quickpoint but I assume it's yet another improvement.
artisanstone is offline
The Following User Says Thank You to artisanstone For This Useful Post:
SmallTownGuy (01-03-2018)
Old 01-03-2018, 07:09 PM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 5,448
Hopefully they removed the lichen and applied a good sealer when they finished.
No grout bag or quick point for me...I'm too friggin' stubborn and awfully quick with a slick...plus I hate plasticizers in pointing mixes, it removes the wholesome feel of real mud.
As well, I'm naturally attached to string lines so my technique would have been similar.
supersealconstruction.com
superseal is offline
Old 01-04-2018, 09:46 AM   #6
fjn's Avatar
Trade: mason
While I seldom use a plasticizer in mud,for the Quickpoint gun it is not needed. The times I find it useful is pointing work on cloudy,damp,cool fall days. Reason being,they are water reducers,thereby less water in mix means you don't have to wait forever to tool joints.
fjn is offline
Old 01-06-2018, 07:54 PM   #7
JBM's Avatar
Trade: Masonry
Rewards Points: 4,722
The part that makes the quickpoint awesome isnt how fast you can fill the joints, but how fast someone that cant joint can fill the joints.
JBM is offline
deteriorated block on chimney rebuild or patch/parge stoneobsidian Masonry 3 12-02-2015 08:20 PM
chimney rebuild quote Pete'sfeets Masonry 37 06-11-2013 08:26 PM
Chimney rebuild JBM Masonry 17 07-22-2012 09:57 AM
Chimney Rebuild on Slate Roof Burns-Built Roofing 25 02-19-2010 10:07 AM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 08:35 PM
