Trade: GC/Developer
Rebar/Grade Beam Schedule
I have worked my way up from kitchen and bath contractor to doing full gut rennovations. But this is my first time I had to do reinforced grade beams from plans.
Can someone explain the attached grade bream/rebar scheduleto me. In particular I dont understand the top re-enforcing as it is broken out into Cont., L and R while the bottom is just bottom. GB3 and GB4 are the only grade beam sizes that are in the drawings. GB4 has (3) #5 on the bottom and (4) #5 on Top - Cont. No real problems there. GB3 has (4) #5 on the bottom and (2) #5 Top Cont, (2) #5 Top Left, and (2) #5 Top Right. Does GB3 just have 6 peices of rebar on top or is there more to it then that? Is it common to have more rebar on the top then the bottom? All my details have the same amount of rebar top and bottom but the schedules all have more on the top. Of course they say to see the schedule so I realize the detail is somewhat generic. Is there a must have book on rebar and forms that will give me more knowledge? Last edited by personalt; 01-16-2008 at 05:06 PM. |
Re: Rebar/Grade Beam Schedule
Always follow the schedule.Quite often there is more steel on the top,but that really depends on the structual engineer.My theory on steel is that it's relatively cheap and as long as you have the neccessary clearances,you can't have too much.When in doubt,use it.
http://www.cofc.edu/~library/addlest...gress/mar.html Last edited by tkle; 05-03-2006 at 05:08 PM. |
| Beam Specs | ophnurse | Framing | 19 | 10-02-2007 08:21 AM |
| flitch beam installation | kweber | General Discussion | 4 | 02-04-2007 11:43 AM |
| Main beam sagging 1/2 inch? | AllGoNoShow | Construction | 10 | 10-12-2006 08:20 PM |
| Beam Support Issue | HandyAl | General Discussion | 5 | 06-15-2006 11:11 AM |
| deck beam sizing and post spacing? | diyerforever | Decks & Fencing | 5 | 05-10-2006 10:58 PM |
