Re-Stucco Application Hard Coat EIFS
Old 08-07-2009, 05:05 PM   #1
plazaman's Avatar
Currently do a job with an EIFS system on wall. Everything looks beautiful and now the customer want something done with the foundation, a smooth finish.
Its heavily textured stucco finish on the foundation.
1) My thoughts were, Basecoat and Mesh over the foundation, but im thinking it gonna take alot of basecoat to get it right.
2) Re-stucco over existing finish and paint to match wall color. with bonding agent on existing finish. 1 coat.
3) Cup grind texture to knock down high spots and mesh and basecoat.
4), Glue EPS board to the foundation walls, and finish as normal.
what do you guys think? least expensive method and long lasting...
plazaman is offline
Old 08-07-2009, 10:30 PM   #2
Tscarborough's Avatar
Re: Re-Stucco Application Hard Coat EIFS
What is behind the stucco on the foundation, i.e. what is the foundation wall makeup?
Tscarborough is offline
Old 08-08-2009, 08:57 AM   #3
plazaman's Avatar
poured foundation
plazaman is offline
Old 08-08-2009, 11:07 AM   #4
LET ME SHOW YA SOMETHIN!!
CrpntrFrk's Avatar
Trade: I do that too!
I would use part of #2 first then finish it off with the last of #3.
Stucco over the existing stucco to smooth it out. I don't know (with out seeing) what "heavily" means. My choice might change if I saw a picture. Anyway after that then use the base coat. Not sure why you would need the mesh unless the foundation has lots of cracks or you just like the insurance of the mesh.
DO IT!! DO IT!! DO IT!!
CrpntrFrk is offline
Old 08-08-2009, 03:07 PM   #5
What is the offset between the face of the wall and the face of the foundation?
Old 08-09-2009, 09:18 AM   #6
plazaman's Avatar
The offset is 1.5 inches ...
plazaman is offline
Old 08-09-2009, 01:29 PM   #7
Last question: Does it have weep screed or J molding on the bottom of the EIFS?
Old 08-09-2009, 06:12 PM   #8
plazaman's Avatar
I installed starter tracks with weep holes for eifs drainage. What do you mean by a j mouling for the bottom? Any pics
plazaman is offline
Old 08-09-2009, 06:28 PM   #9
CrpntrFrk's Avatar
He means j weep but I was taught EIFS does not need j weep.
Old 08-09-2009, 07:16 PM   #10
plazaman's Avatar
yes, eifs does require drainage. heres a pic of what i installed
plazaman is offline
Old 08-09-2009, 09:08 PM   #11
My recommendation is thus:
Grind off the high points of the rough finish with a 9" grinder.
Use a high build base coat to slick off the foundation.
Use the desired acrylic finish coat, and be sure to leave the weeps of the EIFS above clear.
The Following User Says Thank You to Tscarborough For This Useful Post:
concretemasonry (08-09-2009)
Old 08-09-2009, 09:38 PM   #12
plazaman's Avatar
where would i get a high build basecoat? i never really seen such a product before.
attached is a pic of the texture. whats the name of this particular texture?
plazaman is offline
Old 08-10-2009, 12:06 AM   #13
CrpntrFrk's Avatar
See I had a Parex Eifs rep stay with us on a job till completion and we stapled the mesh to the osb the when the foam board was installed we wrapped the mesh from under to the face of the foam board with the base coat. Not saying anybody is wrong just I figured this guy was sent to us by the Parex Eifs company.The rep was from NY and he was a plaster guy. Only had one good eye.
That texture seems to be a type of skip trowel. Very popular here in AZ.
Stucco on concrete Stone Masonry 4 06-01-2009 07:53 AM
Matching to old stucco oldfrt Masonry 4 04-30-2009 08:14 AM
Please help with stucco texture Josh Hildebrand Masonry 1 03-17-2009 11:05 PM
eifs problem Dorin Morgos Masonry 24 10-05-2008 04:10 PM
2 coats or one coat saucedo80 Painting & Finish Work 38 03-02-2007 08:23 PM
