Quikcrete Mortar Mix For Stucco Base Coat
Hello to all. I just put a base coat of Quikcrete mortar mix on some exterior block walls around my house. They have been sitting for some years and never finished them. I pressure washed them and hit them with a muriatic acid solution first. I did not realize the mortar is type n, should of used type s or m or do you think i will be alright? Going to put California stucco over it. Still have some to do. Any Suggestions will Help! Thanks Poppy
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Trade: Concrete/Masonry
Rewards Points: 70
Re: Quikcrete Mortar Mix For Stucco Base Coat
What is California stucco?
Advertisement |
Rewards Points: 70
Ha, google is my friend.
I thought it was a specific style, not a brand. If it is an EIFS finish coat you will probably be fine. I have that stuff on some clothes still from about 6 years ago, the pants are worn down to nothing and the EIFS is still brand new looking, tough stuff. |
It's the brand name (California Stucco) out of New Jersey. Standard masonry stucco
Rewards Points: 1,402
No worries, but next time add some fibermesh and latex bonding adhesive.
The Following User Says Thank You to Tscarborough For This Useful Post: |
CrpntrFrk (10-18-2011)
Want to play a game?
Trade: I do that too!
Rewards Points: 4,196
Around here something such as Western One Coat should have been used. It has the fiber mesh that Tscarborough mentioned.
My tools are always yelling at me cause the wife and kids take up too much room. |
On the the north side of my front stairs where there was some mold before I cleaned it I brushed on Stuccobond diluted 50/50. I tried chipping away some on that wall and another that I didn't use bonding agent and seems to be well adhered. The one wall left on main house do you guys think I should use type S mortar or am I worrying for no reason? I may also want to switch to Sonewall acrylic stucco but someone told me it might be a problem over mortar with lime. Also can go over 20 year old standard stucco with the Sonnewall after pressure washing it?
For stucco, Type S or N is really a meaningless standard. How much compressive strength do you think you need? Is like Superman pressing against the wall?
For stucco, you want flexural strength and minimal plastic shrinkage, so a high lime, fiber reinforced mix is best. |
Thanks T, I was worried but not anymore. You guys are great. I'm new to this site, it's the best
Mad Italian
Just out of curiousity who advised you to use either type n or type s mortar as base coat for EIFS?
I have never heard of this being done so I cant speculate. If you are planning to do regular stucco I do not get why would you want mortar instead of portland mix? You are going to have headache with brushing/rolling bonding agent on(waste of time). If you are planning to do EIFS why not to just get regular base coat for acrylic? |
Not knowing anyone to ask and always relying on myself I usually do the right thing. Unfortunately not having enough experience and being in a hurry this is what I did. It may not be right but if it will do the job I will be happy and learn from my mistake. Twenty years ago when the house was built I mixed from scratch sand, couple of shovels of lime and maybe 15-20 shovel of sand for base coat and lasted excellent. Life hit and never finished. I don't know that's why I'm here!
Trade: Masonry
Rewards Points: 4,126
California Stucco doesnt require anything underneath it. It is the god of stucco. Scrape it off and put the CS directly on the block.
#13 | |
Mad Italian
Re: Quikcrete Mortar Mix For Stucco Base CoatQuote:
Thanks a lot ![]() |
Trade: Masonry
Yeah its made by Silpro. Very similar to Utrowel by Umaco. I labored on a block wall on a garage that was stuccoed with this stuff in 1986. It looks pretty much exactly as it did when I was sponging it. I also did a block retaining wall at my parents house when I was 20, 21 years ago. Looks exactly the same as the day I finished it, save some dirt on it.
Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Factory finish on FC: One color coat only, second in field | UpNorth | Windows, Siding and Doors | 2 | 11-27-2010 07:40 PM |
tuckpointing 1890 home | les digits | Masonry | 27 | 08-15-2010 05:04 PM |
Clean mortar off of Glass block??? | Nobreus | Masonry | 21 | 09-11-2009 06:59 PM |
Scratch Coat | bline22 | Masonry | 23 | 03-01-2009 08:03 PM |
1st Row of Bricks on Lentil Dry, In Mortar, or Either? | TomBrooklyn | Masonry | 16 | 08-30-2008 03:01 PM |
Go to Page... |
