Question, Stone Veneer
conditions as follows, see photos please
1-slate veneer with mesh backer 2- 36" high around perimeter of house 3- install over 3/4" cdx install procedure i would like to use 1- 30lb felt paper over cdx ply 2- plastic drainage roll stapled over felt 3- cement board nailed over drainage mat 4- thinset directly to cement board QUESTION i have heard alot of conflicting opinions, manufacturers of stone veneer, and masons have said the best way is 30lb felt, plastic drainage mat, nail diamond lath, scratch coat, thinset veneer to scratch coat. i will install the best way available, i would just like to understand why i am using one technique over another, thankyou, Gene http://
Re: Question, Stone Veneer
The lath and scratch coat is cheaper and in my opinion gives a better bonding surface. I use the board inside when I want to keep the mess to a minimum.
There are several manufacturers of your stone. Some of the backing will come off when it is cut. If the backing is holding your pieces together it falls apart. The preferred method is when the stones are epoxied together. Open and check all boxes for breakage.
Trade: Stonemasonry
I don't think anyone really knows the right answer. This kind of thing is kind of a bastardized technique that's halfway between tilesetting and stonework, but not truly either one. That said, it's great that you are using a drain board behind it. Just make sure that your flashing details are correct at the top of your stone, and especially under windows. Make sure your weep areas are clear (and remain clear) as well. Your other option is to use a tile product like Schluter's Kerdi behind the stone, and tie it into your upper drainage planes.
Bill Baddorf Bill@artisanstoneworks.net www.artisanstoneworks.net www.stonefoundation.org |
If you use cement board (taping the joints), then thinset to set the stone, anything else is a waste of time and money. I would ask why the plywood and the roofing felt?
It ain't Rocket Science unless you are building rockets. |
Trade: Masonry
Stone veneer around here is 6" thick.
Here, it is 4". He actually meant adheered veneer, which is a whole different kettle of fish.
#10 | |
Trade: Masonry
Re: Question, Stone VeneerQuote:
It's to the point now that I won't do a true stone veneer with less than a 5" shelf.
Trade: masonry
Up here in WI we just put our felt over the plywood and housewrap.
Then attach the lathe and scratch it. I've never used the drainage mat, or heard of anyone up here using it.
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
| Stone Veneer | Marcus W | Concrete & Paving | 1 | 02-28-2008 10:15 AM |
| Exterior Artificial Stone, Wall Veneer | MST | Masonry | 6 | 09-13-2007 09:47 PM |
| Removing old stone veneer... | KAT_Ayanami | Masonry | 3 | 06-11-2007 11:09 PM |
| Mortar Bedding for Stone on Concrete Question. | lukachuki | Masonry | 10 | 05-26-2007 10:09 PM |
| Post your question for Michael Stone | Nathan | General Discussion | 16 | 08-31-2006 08:34 PM |
