Question On Residential Brick Veneer
Guys,
Recently I have been reading/hearing that the standard airspace for behind brick veneer is now 2". We'll be doing brick veneer on all 4 sides of a residential ranch house. The plans call for the foundation to be 10" wide. This, of course, will not allow for a 2" airspace. Can somebody help clarify the airspace mystery here? ![]() Also, the architects plans call for no base flashing. This is normally something that the architect specs, right??? |
Trade: Masonry consultant
Re: Question On Residential Brick Veneer
Sounds like a poor set of plans with no flashing. Do the plans specify a 2" space or not. Is there a detail that shows the brick ledge, lack of flashing and a 10" foundation wall? If not, throw it back to the architect to determine the detail and get you off the hook for the responsibility. - What kind of ties are specified?
Some codes permit a small (less than 1") space, but most codes and standards are going toward a 2" space. This is a result of the slop in the space that greatly add to leakage problems even if there is flashing. Not having flashing and weeps is even worse since it leads to bigger problems like mold and rot. The good thing about the 2" space is that you will have better looking knuckles. If you get permission, you could always hang the normal size brick out over the foundation wall a little to make brick work a little easier.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
I'll be reviewing the plans this weekend. With a 2" airspace, what the heck do you do around windows/doors?!
#4 | |
Re: Question On Residential Brick VeneerQuote:
If no one let the carpenters in on this little gem the flashing details will be nasty. Doesn't seem a well though out idea to me. All window and door details would have to have a complete remake, and I haven't noticed any new provisions with any of the mfg's I deal with.
I have only seen the 2" for commercial to this point, but it will eventually filter down.
It ain't Rocket Science unless you are building rockets. |
Trade: masonry
you return your brick into the doors and windows.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Do you miter cut, or are there
tiny pieces every other course? Just trying to get a grip on the whole picture here.
Trade: masonry
I think he meant highlight the doors and windows.
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
I understand the return, though
not the details of how it might be done to look good. I don't understand "highlight." Would that be like a surround, or kind of a picture frame?
Going to stick with a 1" airspace. Brick will overhang the foundation wall by about 3/8".
Anyway, are there any new and recommended flashing materials out there that I should know about? Architect has not provided flashing details, I will ask him to do so. |
Trade: masonry
no i dont miter cut the brick.
i will lay a batt or double batt around the windows and doors.this allows the brick to catch the moulding around the windows and doors.most times i will leave the batt out 1/4 to 3/8 from the field brick
#12 | |
Trade: R.T.W BRICK & BLOCK WORK
When i brick a house i try to stay about a 1 3/8" away from the house, but ya on commercial 2" , and around your windows and doors they have a flashing for that as well , but like concrete says what the heek is up with your prints?
| Thin Brick, VS Regular Brick | Project53 | Construction | 25 | 03-11-2010 03:13 PM |
| concrete pour on top of brick stoop | 72chevy4x4 | Masonry | 0 | 09-11-2008 10:09 PM |
| Residential POCO transformer question | Mark Twenhafel | Electrical | 10 | 12-02-2007 04:07 PM |
| wire behind brick | hurricaneflyer | Electrical | 7 | 11-13-2006 08:03 PM |
