Trade: Masonry
Question
Capping a concrete porch with flagstone.
The roof of the porch is held up by two 4x4 posts. I am reluctant to just build around these posts as the wood is sure to rot out eventually. http://image24.webshots.com/665/3/21...8hpwMVP_ph.jpg Not the best photo and I believe the posts in question are obscure, but I had to show you something. I know I am not the only one here who has encountered this before--one of you must have a better/more costly solution then I can come up with. Any help is appriciated. Last edited by Rock Headed; 06-18-2008 at 09:27 AM. |
Steve
Re: Question
Can you undercut the wrap? They look bigger than 4x4
Trade: Masonry
Re: Question
Um, define wrap, please.
My initial thought was to prop up the porch, trim the posts, lay flagstone, rest set posts atop the flagstone. Of course I would need to let the mortar cure....so only the stone beneath the posts would be set at first---the adjacet stones not yet set as the props would occupy their space. Time consuming and costly! I need a better solution, and since my head is full of rocks, I come here for help. |
Steve
Re: Question
It looks like 4x4's wraped with 1x6. I'm thinking you could undercut the 1x6 enough for your flag, seal cut and clear silicone after
Al Smith
Re: Question
I would never embed the posts nor would I cut back the wrap only and leave the post. this will create a capillary problem and those post will start to rot in one year. I would get a metal post stand off put it under the post and on top of your flagstone. or on concrete equivalent to the surface elevation of your flagstone would be better. Yes its tedious but its the right way.
Re: Question
I am "Forbidden" from
seeing your pix, but when resurfacing a porch, I use temp props set outside the footprint of the porch. double some 2X6, cut a bird's mouth to get a bite on the beam, and snug them in at a slight angle just off the porch sitting on a block or a scrap 2X12. I've had porch roofs sit like that all winter waiting on weather to pour a slab. Replaced a lot of wood porch floors the same way. What Al Smith said is for sure the truth.
Al Smith
Re: Question
If you refresh the page or paste the link it works. But damn if i can even see the dark brown posts with all that tudor
#8 | |
Re: QuestionQuote:
what I do?
#9 | |
Trade: Masonry
Re: QuestionQuote:
Neo, you are right. I can prop the porch, with the props set at an angle, complete the capping and then re-set the posts. The posts will tie into the flagstone via "U" shaped metal brackets, which anchor into the stone on the bottum of the U and into the wood along the sides of the U. Sorry if i am going into laborious detail here. I am being underbid by some guy who likely is planning to embed the posts--which I would never do. I need to try and get all these details figured out so I can offer a competitive price without sacrificing quality. Thank you everone for replying. If anyone can offer any more alternatives, or clarifications, I am still reading and appriciating. |
| Sewer Infrastructure Question | ABLE1 | Excavation & Site Work | 20 | 05-28-2008 11:05 AM |
| Firewall question | Derek13 | Commercial Construction | 3 | 12-11-2007 04:52 PM |
