Precast Anchor Options
Old 01-18-2008, 11:07 PM   #1
WARD's Avatar
Trade: masonry
I am working on a project were precast pieces are to be installed above stick on stone with a metal stud/densglass wall backing. The precast pieces are (very) roughly 6"x4"x48" and aproximately 50lbs each. I am looking for a good way to anchor them to the wall. Airrscraft makes a s.s. clip system that will work, and for now that is our plan, but it is rather expensive and the lead times are rediculous.
Options?
TIA
WARD is offline
Old 01-18-2008, 11:39 PM   #2
Tscarborough's Avatar
Re: Precast Anchor Options
Unless you are willing to assume an undue amount of liability and an engineering review as well as the associated expense, I would stick with the specified anchoring system.
My standard response to "it is rather expensive and the lead times are rediculous" is:
You bid it off the specs, so it is expensive only to the owner, and I would presume you signed your contracts with plenty of time to order the specified materials.
Good luck!
Tscarborough is online now
Old 01-18-2008, 11:48 PM   #3
However, if you are in the pre-bid or VE stage, there are probably some options.
Old 01-18-2008, 11:59 PM   #4
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
RFI to the GC/Architect/Engineer/Owner to request a change in specs.
Chris
Chris Johnson is offline
Old 01-19-2008, 12:12 AM   #5
Good luck with that if the lead time is already an issue.
Old 01-19-2008, 08:48 PM   #6
WARD's Avatar
Trade: masonry
Good luck!
I would normally agree with you, but the circumstances on this project are a little different than normal. Its a desgin build, that should be classified as a build then design. The project is on its 12th set of prints.
So what are the other options? Any possible options will have to be submitted and reviewed by multiple eng firms.
WARD is offline
Old 01-19-2008, 09:08 PM   #7
Without looking at wall sections and sill, parapet, and column details, I could not even begin to guess.
precast concrete repair masonlifer Masonry 9 07-02-2007 12:48 PM
Precast concrete swale ideas? joesauers Masonry 4 06-20-2007 10:15 PM
Advice on Precast Stone sills for Stick-on Stone turbomason Masonry 6 03-04-2007 12:44 AM
precast ciddio Masonry 3 08-30-2006 07:08 PM
I need precast steps or a mason. Massachusetts Rich Masonry 0 08-02-2006 05:41 PM
