Pouring Over Existing Decent Slab
Old 01-15-2018, 08:57 PM   #1
Stultzlawncare's Avatar
Trade: Landscaping
I have a 15 x 20 foot garage floor poured about 12 years ago. It isn't in bad shape it just wasn't poured smooth and I'd also like a drain on it. I'd like to add 3 foot to the front also. It has one hairline crack on it but that's it. Could I rough the surface up and pour 3 inches over the existing slab and pour the new part 5 inches thick?
Stultzlawncare is offline
Old 01-16-2018, 08:03 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,082
Re: Pouring Over Existing Decent Slab
Enclosed garage... Go ahead, you don't need to rough anything up since heaving is not a concern. If you want Concrete Bonding Adhesive to the existing floor, other than that the slab is not going anywhere.
greg24k is offline
Old 01-16-2018, 09:33 AM   #3
Trade: Landscaping
Ok thanks man. Since the front of the new slab will only be covered with stone up to it level should I dig down 2 or 3 feet to avoid lifting in the winter?
Old 01-16-2018, 01:44 PM   #4
Fishindude's Avatar
Trade: Industrial
Rewards Points: 236
Tear it out and start fresh or you will have problems. Any cracks in the existing slab will telegraph up thru the new slab.
Fishindude is offline
Old 01-16-2018, 01:47 PM   #5
Trade: Landscaping
Even if I use the fiber mesh 4000 psi?
Old 01-16-2018, 04:20 PM   #6
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,178
A Concrete contractor that I know bought an old building to use as a mechanic and storage shop for their equipment and did just that since the mechanic wanted a smooth floor instead of the pitted, cracked and uneven floor that was in there.
I believe their pour was 4 inches right over the top and they drive heavy trucks (semis) on it...
Windycity is online now
Old 01-17-2018, 08:19 AM   #7
http://penncoatinc.com/
PennCoat's Avatar
Trade: Painting / Epoxy Flooring / Polished Concrete
Rewards Points: 706
make sure the existing concrete is sealed. dump some water on the surface and see if it beads up. If it does, then it's sealed. If it gets absorbed in the concrete, then whatever you top it with will likely dehydrate. And if the new pour dehydrates, then it likely won't bond very well, and you could hear some hollow spots down the road. Or you could get some alligatoring in the finish.
PennCoat is offline
Old 01-20-2018, 11:35 AM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,637
Option B: Polish/ grind old surface, caulk crack. Rent a terrazzo grinder and edger. Use the welder outlet or electric dryer plug in?
Leave old crete, drill (as far out of plumb as practical) in 1/4" holes with hammer drill, install a U-shaped, galvanized 1/4" wire 'Staple' between two holes that the is about 1.5" above the old floor to mechanically bond the slabs together.
Two pieces of material fastened together are twice as strong in bending as two pieces just laying on one another....
At some point it is cheaper to demo the old crete, dig down the rock/ sand base, (for max load capacity, at least 2 x concrete thickness for base material) for the replacement products.
Fouthgeneration is online now
Old 01-20-2018, 11:46 AM   #9
Trade: Landscaping
Thanks for all the replies. I ended up tearing it all out and it is kinda muddy under and was actually frost under the first 4 feet. I'm thinking I'm going to dig down to solid ground then add Maybe 6 inches of 3a modified with a power tamper then my 2b then concrete. Also dig down around the edges about 2 foot for frost.
Old 01-20-2018, 04:40 PM   #10
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,824
nope
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 01-20-2018, 08:52 PM   #11
fjn's Avatar
Trade: mason
Rewards Points: 8,484
2 " High density foam made specifically for placement under concrete would give you better results. It would work as a vapor barrier and insulation.
fjn is offline
Fouthgeneration (01-21-2018)
Old 01-20-2018, 09:58 PM   #12
JBM's Avatar
Trade: Masonry
Rewards Points: 3,488
Is there a frost wall there?
JBM is offline
Pour a slab around existing 6x6 PT Columns? LewLew General Discussion 4 01-14-2015 06:15 PM
Pouring a 12x20 concrete slab for a garage. CJ21 Concrete & Paving 26 05-12-2013 10:24 AM
Framing addition - Matching existing roof plane ncornilsen Framing 18 01-11-2013 12:47 PM
Flagstone over slab paulbronson Flooring 2 10-26-2009 08:15 PM
granite slab handling archibaldtuttle Kitchens & Baths 3 10-12-2009 08:25 PM
