Porch Footing - Masonry - Contractor Talk
Porch Footing
Old 06-11-2010, 09:12 PM   #1
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Porch Footing
This customer wants this porch and sidewalk replaced with a brick paver porch and walkway.
He wants the porch extended out 2 feet so that itís flush with the edge of the garage.
Iím a roofing contractor in Michigan. We did the roof for this customer and a chimney repair. The mason that did the chimney repair said that a footing is not required.
We are planning on building the porch out of landscape stones and brick pavers.
Would I be required to put in a footing for the new porch?
MEL
MEL is offline
Old 06-11-2010, 10:35 PM   #2
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
Re: Porch Footing
Sounds like you don't trust your mason.....ideally, the support for this would go down to undisturbed with the basement/crawlspace....perimeter filled in, pad poured and units layed.....maybe your mason is thinking pad as opposed to footing, I don't know....I personally would go down per your code, you might find the original footing for the landing....I would drill in a few rebar pins, pour and build....I would be concerned that without a proper footing, you will get separation at that "seam" down the line....you will get other opinions, but that's my 2 cents......gl Are you going to clear that, hmmm, is that a japanese maple?
Last edited by Rockmonster; 06-11-2010 at 10:37 PM. Reason: just noticed something
Rockmonster is offline
Old 06-11-2010, 11:29 PM   #3
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Porch Footing
The mason assured me that the footing wasnít necessary but a permit is required. I havenít talked to the building inspector yet.
I already gave the customer a quote. They want a slightly different design so Iím supposed to get back to them on Monday. The original footing could be used on the side, it would have to be extended 2 more feet and a footing 12í long would have to be made for the front of the porch. If a footing is required than I suppose the steps should have a footing also.
If thatís the case the mason screwed me because I asked him if it needed a footing before I submitted my quote.
I think the mason said he was going to put down gravel and compact it instead of a footing.
I'm not sure if that's a Japenese maple but he wants us ti rip it out along with the shrubbery.
MEL
MEL is offline
Old 06-12-2010, 12:20 AM   #4
Captainsls's Avatar
Trade: HARDSCAPE
Rewards Points: 350
Re: Porch Footing
MEL- It sounds like your mason is heeding your client’s request by using a concrete paver for the landing extension and walkway. This system is a flexible system and does not rely on a monolithic footer. Compacted aggregate is the appropriate base material for the construction.
I would speculate he plans to build a segmental retaining wall starting by the garage wrapping back to the house, and backfill over the existing masonry landing, then dry lay the field with pavers. As long as there has been no movement with the existing porch and he compacts the new area correctly; there will be no problem having the flexible system laid over the masonry.
No one is screwing you. Just ask him for his construction plans and confirm that it’s a flexible system.
Then again, if he were using brick and mortar I wouldn’t trust him either. Rockmonsters advice is right on if that’s the case…
Captainsls is offline
Old 06-12-2010, 12:24 AM   #5
Captainsls's Avatar
Trade: HARDSCAPE
Rewards Points: 350
Re: Porch Footing
Looks like a bloodgood maple which is a Japanese maple tree. Not sure though???
Old 06-12-2010, 12:49 AM   #6
Moderator
Double-A's Avatar
Rewards Points: 2,000
Re: Porch Footing
You might price that tree locally. I would get a pro in and have it balled, even if the client wants it trashed. I think you'll find that tree, especially with the triplet trunk is worth almost as much as the mason's work.
In this area, they cost a small fortune.
"My clientsí wishes are the center of my attention." -- David Guido, a contractor in Woodstock, N.Y.
New York Times, July 20, 2006
Double-A is offline
The Following User Says Thank You to Double-A For This Useful Post:
MEL (06-12-2010)
Old 06-12-2010, 08:55 AM   #7
MAULEMALL's Avatar
Trade: GENERAL CONSTRUCTION
Rewards Points: 98
Re: Porch Footing
Here as well...
MAULEMALL is offline
Old 06-12-2010, 11:23 AM   #8
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Porch Footing
How much do you think I can get for it?
MEL
MEL is offline
Old 06-12-2010, 12:09 PM   #9
natural1's Avatar
Trade: Landscape contractor
Rewards Points: 344
Re: Porch Footing
That is a bloodgood maple. Pricey trees. It would be a difficult tree to transplant especially this time of the year. I think you would be hard pressed to find someone willing to take the effort and risk to dig that up.
Sounds like the porch will be constructed using segmental wall units so I agree not concrete footing. An appropriate compacted gravel base is required.
Mike
http://www.natural-designs.com
natural1 is offline
Craftsman Porch Footing Gary1 Remodeling 4 03-25-2010 05:56 AM
drain pipe through footing m1brown Concrete & Paving 4 02-01-2010 08:31 PM
Porch Column Repair mpt1123 Historical Restoration 5 01-11-2010 06:33 PM
expanding a masonry brick porch INTRA Masonry 4 12-24-2009 01:19 PM
Porcelain Tile Porch jbtn9 Flooring 1 09-22-2009 03:45 PM
