Trade: Carpentry / Fencing / Decks
Plumbing A Brick Column
I have a customer that has a brick fence. I am tearing down the fence between the brick columns and putting up a decorative wood fence in its place.
One of the columns is leaning due to a tree root that grew under it. I have not looked at the columns up close yet so I do not know if there is a footing under them. The tree has been removed and I need to get this column plumb again. I am planning on digging out around the column, plumbing it and pouring a new footing under it. Any advice or suggestions?
www.ParkerFenceandDeck.com |
Chief outhouse engineer
Trade: mason
Re: Plumbing A Brick Column
I suppose it is worth a try. Everytime I try something like what you described I end up building a new one.
![]() How do you intend to support the post as you pour the new footer? If the total height of the post drops a couple of inches, will it be obvious to a casual observer? I would porbably warn the customer that a new post may be necessary if something happens. Not sure this is any help, but ...
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. |
#3 | |
Re: Plumbing A Brick ColumnQuote:
The column heights vary already as this fence is probably 50 years old and some seem to have settled a bit. I had envisioned supporting the column with 2x4 braces but I do not know how realistic that would be. I do not have any experience with this type of situation and I may call a mason to sub this out but I would like to get a few ideas here first. Thanks
www.ParkerFenceandDeck.com Last edited by curapa; 03-12-2009 at 02:42 PM. |
#4 | |
mason
Trade: Mason contractor
good luck
http://www.diamondqualitymasonry.com/ |
Trade: masonry
i agree that your best bet would be tear it down and replace it.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
| Thin Brick, VS Regular Brick | Project53 | Construction | 25 | 03-11-2010 03:13 PM |
| Adding a Brick Ledge to a Michigan Home | bajafx4 | Masonry | 3 | 01-23-2009 07:19 PM |
| ICF brick ledge | coupe33 | General Discussion | 7 | 11-29-2008 01:45 AM |
| concrete pour on top of brick stoop | 72chevy4x4 | Masonry | 0 | 09-11-2008 10:09 PM |
| DIYers in the Plumbing Forum | 22rifle | Plumbing | 49 | 06-23-2008 12:42 AM |
