Peeling Concrete, Best Way To Fix?
Hey guys,
Good friend of mine has some small areas of a concrete landing on his front steps that are peeling, from a weak mix I suppose. The aggregate is revealed, he tells me. Growing up in the business, we would use thinset to top the slab in these scenarios, then sponge float it to a rough finish. I've also heard of a product called Top N Bond (spelling?). Are there any other products I should be aware of? I don't do many repairs like this typically, but it's a friend. Told him I would go over one weekend, have a look, and have a few beers. How would you guys address this? |
Re: Peeling Concrete, Best Way To Fix?
Get a resurfacing product, clean the crap out of the surface, fill the holes, then rub it all for a consistant finish.
It ain't Rocket Science unless you are building rockets. |
Tscarborough - Any particular product recommendation? No-no on the old fashioned thinset idea?
I don't consider thinset to be a wearing surface. Concrete resurfacer is a common one, probably available at the big boxes.
Thanks! Has anybody else tackled a peeling slab that has any advice?
Trade: Mason
Top N Bond would work well for that application. Finish it rough or smooth.
Trade: General Contracting
I would have to disagree with all the above. Obviously, the skilled mason BURNED the finish or you have recieved a HOT LOAD .
The above home supplier methods stated above is only a temporary fix. The top&bond for example , will eventually POP too. The PROPER way to solve this problem is to excavate the problem area and replace it with new concrete. |
#8 | |
Re: Peeling Concrete, Best Way To Fix?Quote:
agreed, this would be a reasonable approach to repairing the problem
I'm a Mac
Trade: ICF Construction
Consider a stampable overlay, not only fixes the issue, allows you to give a nice decorative surface as well.
Chris |
Trade: Epoxy Flooring & Concrete Overlays
I agree with chris. As long as its structurally sound there is no reason to tear it out and replace it. Stampable overlay, broom finish, tuscan trowel, all kinds of solutions.
monsterplow may be right about the home center products but the overlays we do are stronger than the concrete itself. Last edited by JBBS; 08-17-2008 at 11:41 PM. |
Sharpie
Trade: Renovation contractor
What about the roll on coatings like "stone effects" or some such bull****. I haven't tried them but if you repair the problem areas and recoat with this stuff it might make for an interesting experiment. Especially over a couple of beers.
Travis www.customkreations.ca "The most perfect technique is that which is not noticed at all" -Pablo Casals |
General Contractor
Trade: Construction Management
Trav , You name it , i have tried it.
Stencil coat too. But it also requires a "topNbond" product for surface imperfections. There is no guarrantee that will hold . ATLEAST in the Freeze Thaw cycle areas of the U.S..
DECOSnowRemoval&IceControl Serving Delaware County & Philadelphia Pa 610 457-9721 |
#13 | |
General Contractor
That is some exceptional work there my friend .
thanks snow, welcome to ct
Is Top N Bond available at big box? Never seen it at any masonry yards...
OK, so it looks like there are several different brands of "Top N Bond". Is any particular one better?
To me, it looks like this stuff is chemically similar to a polymer modified thinset. FYI TScarborough, I just got back from Dallas. I can't believe how cool the temperature was for August!! |
Top N Bond is the same product as Concrete Resurfacer. Just make sure that it is capable of being featheredged (although I always cut a slot at the edge).
#18 |
OK, one more dum-dum question
Seeing that this is the platform on a set of steps (framed with limestone treads)...how would i give the feather-edged Top N Bond an edge? Use a wide jointer perhaps? margin trowel? |
#19 |
Trade: Masonry consultant
Tommy C -
You never said if it was realtively fresh concrete or if it had been in place for a year or more, unless I missed something. If it not fresh and the contractor cannot be blamed, find the real cause. If it is older, tell your friend to find the right kind of deicer to use since everything applied will have some problems when the wrong stuff is used.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
#20 |
Steps have been there since they bought the house...they bought the house about 2 years ago. Says the steps/platform look fairly new. He also said that he has not used any de-icer. I think I've got this covered, I just need to figure out how to give the Top N Bond coat a finished edge. I'll probably use a jointer. Thanks for the replies guys, sorry to turn such a simple thing into a lengthly thread!
| taking a crack at my own concrete work | J-Peffer | Masonry | 9 | 10-25-2010 06:16 PM |
| Advice - concrete Pool Deck coping | ejleonard | Masonry | 4 | 06-17-2008 05:18 PM |
| Concrete countertop acid stain problem | AHS | Concrete & Paving | 12 | 05-09-2008 02:14 PM |
