Pavers Over Concrete - My Cousin's Method
Old 10-19-2009, 10:56 PM   #61
lukachuki's Avatar
Re: Pavers Over Concrete - My Cousin's Method
Originally Posted by NICKPAUS View Post
The $1.79 or my ability to get it done for less than concrete ?
First of all i'm not doubting you....but obviously things are different around here. I pour concrete for about 4.00 a square foot give or take and do pavers for about 15.00 give or take. (I'm talking residential patios here)
Pavers are just so much more work than concrete and materials are more around here as well.
In looking through your pictures I see that we have the same dump truck and plate compactor. I guess you are just more efficient, so good job.
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln-
Less with the jaw more with the paw!
lukachuki is online now
Old 10-20-2009, 11:46 PM   #62
GC
NICKPAUS's Avatar
On smaller jobs when you figure in short load fees and pumper fees is when pavers can be cheaper for me to install than concrete. Finishers still want $250 a day here. I can dump concrete for $60 with truck or dump trailer $40. Base is $20 for dump trailer full (4-5 tons) $30 for dump truck full 6 tons + or another location that is closer $6 a ton.
NICKPAUS is offline
Old 10-21-2009, 03:27 AM   #63
Twisted Cameron
scrapecc's Avatar
Trade: Concrete, Metal buildings
You wanna try to haul concrete around in a dump trailer? WTF are you talking about. I am raising the bs flag on that one. unless I read the post wrong. But it was kind of unclear where you were trying to go with that one.
scrapecc is offline
Old 10-28-2009, 10:48 PM   #64
Penwood's Avatar
Trade: Landscaping
My company has been installing concrete pavers on concrete slabs for over 16 years. All of the projects are as nice and as exact as the day they were installed. We excavate and install clean ½ stone as done in normal flatwork, form and place concrete reinforced with wire or rebar. After the concrete has been finished and cured, the field pavers are set directly on the surface and the border pavers are glued to the concrete with high strength adhesive.
We then brush and water in fine brown river sand that fills any voids and fills the vertical joints to approximately one half the paver depth. This is followed by brushing in polymeric sand to finish off and create extremely stable joints. The end result is a lasting paver project that has no ups, downs or separation.
In regard to the “usual method” of installing concrete pavers on a sand/stone floating base it has been our experience to witness from our competitors work, a very high degree of project failure as in unlevel surfaces, edge roll-off and paver separation. Many of our competitors projects looked great when installed but have not stood up to the test of time.
When you’re experienced in working with concrete flatwork it really doesn’t take that much time for base preparation and the finished project is very durable and professional.
In the end, your work is of the highest quality which means no call backs; your customers are delighted and you can charge for it.
Penwood is offline
Old 10-28-2009, 11:09 PM   #65
concretemasonry's Avatar
Trade: Masonry consultant
If you are installing a non-critical small and lightly loaded paver installation, installing on a concrete slab can work if you can drain the moisture that and prevent the freeze-thaw deterioration common in northern climates. - Polymeric sand is not a cure-all.
If you are into any serious work (like a city streets with heavy loads, a 747 taxi-way or a 100,000# straddle loader) a compacted base (no concrete) and a sand setting bed is the only way that really works. This has been proven for many, many years internationally where the paver history and engineering comes from. - The U.S/Canada only got into pavers in a very small way in the 1970's.
Dick
concretemasonry is online now
Old 10-29-2009, 02:51 PM   #66
izzy's Avatar
TOMMY C,
I don't know allot about this subject but I do know that we had a state engineered job that was installed per plan design very similar to what you have described.
izzy is offline
Old 10-29-2009, 07:40 PM   #67
72chevy4x4's Avatar
I'm just passing through on this thread, but $5 for a ton of base material-is that gravel as in crusher run? I've hauled it straight from the quarry before and it's $14-$15/ton...what gives? You're nto really proposing that you haul concrete from the plant in your dump trailer, are you? My local hotmix plant won't sell to guys w/ a dump trailer-only dump trucks-maybe plants have differnet policy's.
72chevy4x4 is offline
Old 10-29-2009, 10:31 PM   #68
GC
NICKPAUS's Avatar
Its recycled road base for that price not clean rock and sand. The dump trailer loads mentioned are broken up concrete and price to dump broken concrete at recycling plant. They crush it into road base and re-sell it.
One of my customers motorhome + stacker trailer weighs in at 65,000 pounds pavers over concrete would crack in half without some sand to set in. The concrete drives up the price compared to cheap road base.
NICKPAUS is offline
Framing into concrete ceiling user17661 Framing 43 11-06-2011 09:46 PM
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
