Patio Expansion
Old 08-20-2006, 07:34 AM   #1
andy998's Avatar
Question
Patio Expansion
I am not a mason so I need some advice on a job if it is feasible engineering wise.
I have a client with an existing patio 12 x 20. They want to make it 14 x 22 & 5" higher before I add the Sunroom addition. Can I dig and pour a footing around the outside edge of the existing slab and then pour the additional 5" of concrete over the existing slab patio. We are in the north east and am concerned with frost heave of the old patio slab. The client does not want to have to have the existing patio slab torn out.
andy998 is offline
Old 08-20-2006, 09:11 AM   #2
stacker's Avatar
Trade: masonry
Re: Patio Expansion
if they dont want the old slab tour out,that the only thing you can do.i would make sure i pinned the new slab to the old slab wtih rebar.
stacker is offline
Old 08-20-2006, 09:34 AM   #3
Tscarborough's Avatar
Re: Patio Expansion
I am vauge on frost heave, but if you dug the new footings to prevent frost heave of THEM, wouldn't that prevent the interior (old) slab from heaving?
As a side note, I would pour the footings and slab monolithically, tied to the old slab. That 9-10" of new/old slab will give them a very nice thermal mass, BTW.
Tscarborough is offline
Old 08-20-2006, 10:16 AM   #4
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Re: Patio Expansion
Andy,
That's exactly the way I poured the slab for the house I'm building for myself. Extended and raised an existing slab. Been in for 7 or 8 years now, has a two story cmu structure on top of it, and to date, no problems. Of course we don't have frost heave here, but expansive clay soil which gives the same net result.
If the existing slab was designed for the frost heave, and shows no damage or movement, then your plan should work if you make your new footings deep enough.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 08-20-2006, 12:51 PM   #5
Custom Builder
Glasshousebltr's Avatar
Re: Patio Expansion
I'd pour the foundation and footing first, back fill with rock, add an expansion joint, then pour the slab over. This way if the old slab presents a future problem, the floor can be replaced without disturbing the foundation.
Bob
Bob
Glasshousebltr is offline
Old 08-20-2006, 01:01 PM   #6
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Patio Expansion
Yep, seperate footings & foundation for northern climates. Use an isolation membrane between the two slabs, so any current cracks or heaves in the existing slab do not transfer to the new one. Also consider using 2" rigid foam around the perimeter of the foundation to help keep thermal transfer from occuring.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 08-20-2006, 06:32 PM   #7
andy998's Avatar
Talking
Re: Patio Expansion
Thanks for all the great replys to my question.
andy998 is offline
Expansion joints for underground fed meter cans mdshunk NEC Discussion 12 02-02-2007 03:13 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Thermal Expansion Via Iraq jicoll2000 Plumbing 12 12-16-2006 04:05 PM
Expansion lizzydog Flooring 1 10-24-2006 07:54 PM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
