Patch/Leveling Dips In A Patio - Masonry - Contractor Talk
Old 09-26-2017, 09:47 AM   #1
Remodeler
jhicks226's Avatar
Rewards Points: 26
I've got a client that wants stone set on his patio. The slab has it's typical high and low points. I will grind down the high points and level the low points.
Being a patio it has it's drainage slope that needs to stay, so using a self leveler won't work.
What is a best/strong material that will hold up to a freezing climate to trowel and screed in the low areas.
Thanks!
jhicks226 is offline
Old 09-26-2017, 10:20 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 9,560
Re: Patch/Leveling Dips In A Patio
Depending on the stone and thickness there of,I would think you can accommodate the discrepancies with the setting bed. If the "dips" are so severe that that is not possible,I would question if the patio is suitable as it stands.
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
Fouthgeneration (09-30-2017), Kniggit (09-26-2017)
Old 09-26-2017, 11:19 AM   #3
Remodeler
jhicks226's Avatar
Rewards Points: 26
I am using an uncoupling membrane that requires a v-notch trowel. Right now I just need to focus on the best way to level the concrete.
Old 09-27-2017, 03:57 PM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 5,424
Set stones in type S with bonding agent.
JBM is online now
The Following User Says Thank You to JBM For This Useful Post:
TNTSERVICES (09-27-2017)
Old 09-30-2017, 03:39 PM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,839
I don't understand why you want to use thin bed techniques on a thick bed situation....
drop the uncoupling membrane and use a thick mortar mortar that will allow you to vary the mortar bed to achieve your finish grade needed. use a screed and line(s) and or a offset laser.
Are your stone pavers machined to identical thicknesses?
4-6000 psi concrete sand concrete mix with a bonding agent on a power washed and acid etched dry old surface, brush finish?
Fouthgeneration is offline
Grading & base InterCounty Masonry 8 06-11-2013 10:11 PM
Patio doors..... kinda Paulie Windows, Siding and Doors 10 06-08-2013 11:51 AM
Help with ideas, Patio roof kambrooks Carpentry 28 10-09-2012 07:13 PM
24' x 45' Patio with 4 Steel Post Only buddyb1201 Remodeling 11 08-10-2012 12:14 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
