Walsh Construction Svcs.
Rewards Points: 75
![]() Parging A Wall??
Since I usually work with wood, I'm coming here for some direction. I have a customer that has a cinderblock wall approx. 10' wide by 4' high that needs to be parged. What preparations do I need to take to make sure this stuff sticks properly? The area is pretty rough in texture (not new smooth block) but very solid & not crumbling. Also, what material do you use? I heard straight Portland cement, and also Portland cement mixed with sand. Which do you cement guys prefer? Any idea of how much material I will need for this size area? Sorry for all the questions, but like I said...I usually work with wood.
![]() Thanx! Lance |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Re: Parging A Wall??
Plastic cement.1 part to 3 sand.Red rubber float.Wet clean wall.Apply with a circular motion.Two coats or the joints show through.
AdvertisementLast edited by tkle; 12-09-2006 at 09:36 AM. |
Trade: masonry
Rewards Points: 542
if the wall has been treated with paint or waterproofing you will need to apply metal lath.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Re: Parging A Wall?? |
ALL VINYL
Trade: VINYL SIDING CARPENTRY
Rewards Points: 150
![]() Re: Parging A Wall?? |
Rewards Points: 75
Roughly 100 sq.' per batch should give you about a half inch coverage.
Some guys like to add a cup or so of glue to the mix.I usually do,but it's not always neccessary.Some suggest a handfull of fibers though that's possible overkill on a block wall.I've never used them and have had no problems.The float leaves a rough finish able to accept a finish coat.If you want it smooth do a steel trowel finish in the second coat.In this case the fibers would help with hairline cracking. For 40 sq.' I'd get a good quality premix.The coverage should be on the bag but a couple of 94# bags should do it. |
Rewards Points: 1,402
2-80# bags of premixed mortar per coat is plenty.
#9 | |
Trade: Masonry
![]() Re: Parging A Wall??Quote:
#10 | |
Trade: Masonry consultant
Rewards Points: 2,890
Dick |
Rewards Points: 1,002
Nice fish MR. Concretemasonry...what kind and how big?
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 06:16 PM |
Backyard office, retaining, and privacy wall | Team Scream | Masonry | 8 | 08-02-2007 10:27 PM |
moving centennial wall | stacker | Masonry | 4 | 10-19-2006 11:12 PM |
Repairing Jog In Wall for Stone | Nailbird | Windows, Siding and Doors | 0 | 07-20-2006 05:58 PM |
Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 07:31 PM |
Go to Page... |
