Trade: Framing\woodworking
One Coat Ok On Dry Stack Cinder Block?
Just build 3 planter boxes using light weight cinder block (2high). Planning to stucco these but not sure if doing the 3 coat method is needed. As it is now the cinder block surface "looks" like a 2nd coat finish. Thinking of just applying one coat stucco and texturing it. Think I will have problems with adhesion?
Trade: Stonemasonry
Re: One Coat Ok On Dry Stack Cinder Block?
You would have to use surface bonding cement.
Bill Baddorf Bill@artisanstoneworks.net www.artisanstoneworks.net www.stonefoundation.org |
sbc for what?
i know you can use sbc if your dry stacking in order to help the wall stregth, but the wall is already done and filled with cement (plus some strategically placed rebar). |
One coat is OK, but 2 will hide the joints better. You should also add some integral waterproofing, again to help prevent the joints from showing through when wet.
It ain't Rocket Science unless you are building rockets. |
| Vinly Siding on Cinder Block? | Henry5 | Windows, Siding and Doors | 19 | 01-09-2010 06:07 PM |
| R-Value of cinder block | mdshunk | Construction | 39 | 03-10-2009 08:01 PM |
| Cinder Block walls, block filler and a leak...question | SeanATL | Painting & Finish Work | 9 | 03-09-2009 04:33 PM |
| Painting a Cinder block wall? | gary lee | Painting & Finish Work | 4 | 01-18-2008 09:18 PM |
| Hanging objects off cinder block walls | RobertCDF | Construction | 7 | 04-26-2007 10:07 AM |
