#%$@ Old Contact Cement!
Old 07-13-2011, 12:18 PM   #1
Design/Build
EmmCeeDee's Avatar
Trade: Design/Build
Rewards Points: 660
We tore off the old outdoor carpet from a client's front and rear steps (one precast, one poured) and are now trying to figure the most efficient way to remove the 20+ year old contact cement residue beneath. My suggestion is to paint the concrete, but even then the residue is still pretty thick and will need to be cleaned off the treads at a minimum.
Right now I am planning on using a grinder and a wire wheel to get it off but would appreciate any suggestions before I spend the day at it. Thanks!
#%$@ old contact cement!-forumrunner_20110713_131249.jpg   #%$@ old contact cement!-forumrunner_20110713_131322.jpg
EmmCeeDee is offline
Old 07-13-2011, 01:13 PM   #2
MAULEMALL's Avatar
Trade: GENERAL CONSTRUCTION
Rewards Points: 98
Re: #%$@ Old Contact Cement!
I don't think that is contact... You should be able to scrape most of the glue off and then see if your supply house has a product equivilent to one of these;
http://www.senpro.com/index.php?cPath=21_28
MAULEMALL is offline
Old 07-13-2011, 01:18 PM   #3
Carolina Surface Prep
Rob1954's Avatar
Trade: Media blasting and residential restoration
Rewards Points: 202
Contact a mobile media blasting service. Most of it may come off with bicarbonate of soda. If not, fine crushed glass should remove it without profiling the concrete too much. The best equipment would be a wet blasting system like the Farrow process.
Rob1954 is offline
Old 07-13-2011, 01:21 PM   #4
PRO
BrandConst's Avatar
Rewards Points: 1,000
shot blast.
BrandConst is offline
Old 07-15-2011, 01:12 PM   #5
Design/Build
EmmCeeDee's Avatar
Trade: Design/Build
Rewards Points: 660
You are correct maulemaul, it is not contact cement, and based on a few test spots I think the wire wheel is not a good choice to take it off. I am going to find a supplier for that stuff you mentioned.
If that doesn't work there is always the media blasting. Man what a pain!
Thanks all.
Old 07-15-2011, 02:11 PM   #6
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,102
floor scraper will take the majority off. (keep changing out to fresh blades). Lacquer thinner or mineral spirits should close the deal. good luck
parkers5150 is offline
Old 07-15-2011, 03:31 PM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,268
If it gaum's up the wire wheel, then it's solvent based adhesive & not water based. Go to your local carpet store & buy a few gallons of adhesive remover. It, combined with a floor scraper & it'll be clean in no time. Keep painting it with the remover & scraping & repeating. We deal with this stuff quite often in the hardwood floor business.
pinwheel is offline
Shelf life of contact cement? 232323 Finish Carpentry 1 03-08-2011 09:20 PM
Contact Cement Thinner Jordy3738 General Discussion 3 01-31-2010 03:15 PM
Cutting Fiber Cement Burns-Built Windows, Siding and Doors 7 01-25-2010 09:27 PM
Cement emergency repairs on EPDM? tekwrytr Roofing 3 08-26-2009 06:36 PM
Cement Contact with Copper Pipe Capt2 Plumbing 11 04-17-2007 08:05 PM
