Lynch Masonry
Ok, How Do I Stage A Metal Roof? :-0
So now im living in Vermont, and Im not used to seeing all this Metal roofing, so I think to myself, Im gonna be screwed if I have a chimney to top out and no idea how to stage the roof to get material up there or to make a place to work. So what are my options! Thanks for the advise
Trade: Masonry
Re: Ok, How Do I Stage A Metal Roof? :-0
I would call a standing seam roof company and pick their brains. If not I would probably make some kind of plywood and rigid foam covering to lay over the roof. Use the foam to hold the plywood up higher than the seams. Then build a 2X6 saddle scaffold.
I wouldn't use foam, how about just wrapping the widest boards that fit the ribs with carpet in a saddle rig?
It ain't Rocket Science unless you are building rockets. |
Lynch Masonry
thanks guys, i cant think of any other alternatives, ecept for a manlift.
Al Smith
I did a search on them and most are not rated beyond 500 pounds so be careful
Trade: stone masonry contractor
I tell um to leave the metal off till I"m done.
Do they do it tho? I always request that(metal or shingle), and it never happens that way. I try to explain that it's easier & less expensive to leave it out & go back to it than it is to go back, tear it off & redo it. So, whatever happens, happens. I do try very hard not to effect the roof, but sometimes **** happens. Kind of inevidable without a lift or a magic carpet
| metal cold roof question ..... | Vermonster | Roofing | 30 | 09-06-2007 01:30 AM |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Metal Roof tied to a Shingle Roof? | JackOfAllTrades | Roofing | 2 | 11-15-2005 12:00 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
