Oil Stains On Flagstone ..
Old 07-06-2011, 10:48 AM   #1
Joe Wood's Avatar
Rewards Points: 526
Well we dripped some compressor oil on a flagstone walkway and concrete driveway yesterday. Not alot but an obvious trail of it.
What can I use to clean it up? I've read TSP, Goof Off, WD 40 ..
https://woodsshop.com/
Joe Wood is online now
Old 07-06-2011, 05:19 PM   #2
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 200
Re: Oil Stains On Flagstone ..
Maybe some mineral spirits would work, I think the best you can do is just try to dilute and wash away what you have, I imagine no matter what you do you though it is still going to ghost.
Do you have a really big pressure washer?
NYCB is offline
Old 07-06-2011, 05:27 PM   #3
Amazon119's Avatar
Carb cleaner.
Amazon119 is offline
Old 07-06-2011, 05:46 PM   #4
Joe Wood's Avatar
Rewards Points: 526
Yeah I'm afraid the stain will ghost no matter. It's a light pink porous flagstone.
My thought was mineral spirits, hhmmm, carb cleaner?
Looks like my landscape guy might be replacing some flag for me here soon.
edit- my landscape guy said to try wd 40 ..
Old 07-06-2011, 06:38 PM   #5
Michael
OntheRocks's Avatar
Trade: masonry
maybe try a poultice. Here's a link for one, http://www.stt-sealers.com/stone-cle...g-poultice-kit. I have used some before to remove food grease out blue stone patios....not this particular one though. I had pretty good results with the one I used. A bit pricey, but more than likely cheaper than picking up and replacing.
OntheRocks is offline
Old 07-06-2011, 06:40 PM   #6
NYCB's Avatar
Rewards Points: 200
I wouldn't use wd-40, seems like it would leave a residue.
Carb cleaner is an awesome idea, brake cleaner also would probably work. Something that will carry the oil and flash dry fast, pure cleaner with high pressure.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
tgeb (07-06-2011)
Old 07-06-2011, 06:41 PM   #7
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Maybe this stuff, but sitdwnandhngon is right.
http://www.topoftheline.com/driveway-stain-remover.html
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 07-06-2011, 06:43 PM   #8
CJKarl's Avatar
Trade: Masonry
Your best bet is some kind of poultice. Seems like the above stuff works the same way.
CJKarl is offline
Old 07-06-2011, 08:45 PM   #9
tgeb's Avatar
Rewards Points: 1,032
I'd hit it with brake clean and mop it up with clean cloths.
Rub some dirt on it, if it cleans too well.
www.gebcon.com
tgeb is offline
Old 07-07-2011, 05:23 AM   #10
NYCB's Avatar
Rewards Points: 200
Take some pictures too, I'm curious to see how it comes out.
NYCB is offline
Old 07-11-2011, 08:45 AM   #11
Joe Wood's Avatar
Rewards Points: 526
Well, we tried 4 different products, 1st a biodragadeable driveway cleaner from AutoZone, soaked each spot 10 minutes while scrubbing, rinsed, not much effect on stains.
went back after f stone walk was dry, and tried brake cleaner, carb cleaner, and wd40. Not much effect on the stains.
Pretty amazing, I thought the wd would stain the stone but it didn't at all.
I think the wd, brake or card cleaner would have worked if I hit it right after the oil was dripped, and not 2 days later.
appreciate the advice folks, better luck next time.
Flooring guys couldn't get out hardwood stains deftworks Flooring 14 11-13-2010 04:48 PM
Question about flagstone patio c.c.co. Masonry 13 10-29-2010 12:00 PM
Bluestone Dust vs Sand under Flagstone DCRehab Landscaping 2 10-12-2010 07:46 PM
sher wood stains. need a color advice from someone familiar with them fix it man General Discussion 4 03-07-2010 09:30 PM
Flagstone over slab paulbronson Flooring 2 10-26-2009 07:15 PM
