#61 |
Yard Boi
Trade: Landscaping
Re: No One Wants A Big Project
That is undeniably cool.
Bob's Lawn & Landscape When You Want The Best Serving the LC Valley & Moscow-Pullman |
#62 | |
Re: No One Wants A Big ProjectQuote:
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
#63 |
Any new pics of this move?
Don't leave us hanging like this! |
#64 |
Working
Yeah sorry I have been working like mad. I have been taking pics just need to up load them. We have had a ton of delays and head scratching moments. I am digging the footings tomarrow, with the house above on cribing. Had to rent a very mini ex as ours was to big and didn't fit under the huse beams. Also did a quick walk through of all the wood work that is ahead of me. Lots of plaster patches as well.
#66 |
Chief outhouse engineer
Trade: mason
Cole,
Your getting your bones on this one, if you can get that thing settled you will have one heck of a reputation. Keep the pics coming. I assume you finally found an ICF man to build the walls.
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. |
#67 |
Working
Looking north out of the house towards the road. The white tube are the grape vines they planted this spring around 5,000 of them.
#68 | |
Working
I went and took some classes that the manufacturer has. Also drove to another site 2 hours away and watched/helped another contractor for free. Did hire a couple guys that have done icf before but they are workers and turn to me for advice. Also we changed the design a little. The ICF wall will be 10' and the last 4'rough face block. Since I am doing this project and am not subing it out. All my other smaller jobs I had to had over to another biz. (father) He is semi retired and is reluctently helping me. The rep has allready started and have only have been on my own a year.(july08) |
#69 |
Trade: mason
Sounds great, I like the split faced block above grade. Digging those footers next to the cribbing looks like a real trip. I could see those trenches wanting to cave in or smacking them with that mini.
#70 |
Working
All the house footings are dug!
Will be setting formadrain tomarrow and digging a couple waste water lines. The pump truck is on call for friday. ![]()
#71 |
What is the footing size?
#72 |
Nice clean dig. I hope it does not rain....
When you first posted, I thought the foundation would be put in first and the building placed upon it. How will you get concrete into the top of the ICF's? Or will you do the foundation and the movers lower the structure? |
#73 |
Working
Size is 18" deep x 36" wide.
The ICF will be 10' high then block up to the house. Pull the beams out then fill in the holes where the beams were. Thanks on the dig I haven't been on a ex in about 2 years. |
#74 |
Trade: Masonry
Dynamite project.....one question though....I've done about 25 of these, albeit never with a full masonry building....why weren't the footings formed? There is a ****load of weight up there, and I have seen cribbing go on one job....the whole house had to be destroyed, although no one was seriously injured. Makes the perimeter drain easier to install as well. Just wonderin' This is a great project however. Real feather in your cap....
#75 |
thanks cole for keeping us up to date....those footings look way smaller in the pictures for some reason....but just shows how deceiving a pic can be.
#76 | |
Working
We had another revision today, so today was a loss and will try and pour monday. Last edited by Cole82; 09-10-2009 at 11:07 PM. |
#77 |
Trade: Masonry
No...by formed I mean formed footings.....we usually have it excavated to the bottom of the footings, form them with 2x12 or 2x10. Goes very quickly. Only thing is then you have to fill inside the footings up to t.o.f. after all the cribbing is out. It is all sand here however....
#78 | |
Working
#79 |
Trade: mason
I have a question about the formed footers. Not to hijack the thread, but more likely to keep it moving as we wait for updates.
What is the advatage of formed footers? I normally don't pour footers, just lay block on them and I have one customer who always forms his, and everyone else pours them in trenches. (usually hand dug, because it is easier to hand dig accurately than trying to get a mini or whatever in the hole and dig) I prefer the trenches as the bottom of the building hole is about level with the top of the footer and easier to lay block on instead of constantly stepping up or reaching out to set the block. Typically the formed footers are more accurate for elavation, but usually the trenches are marked with some type of elevation marker so really not much of a deal. Just curious to know the pros and cons as I am starting to get more requests for footers to be included in my foudation bids.
#80 |
Trade: Masonry
Yeah dak, you're right about the stepping up and reaching part....that's why I always try to have it backfilled (the inside) prior to laying the block. But here's why it works for me; Advantages 1) Far faster to prep... our foundations are generally 160-240 running feet, so form and steel take maybe 6 manhours as opposed to, say 15 or so to dig. (that is with shovels, not a mini ex) 2)Perimeter drains-much easier to put in (Common to have interior and exterior runs here) 3)For parging or waterproofing, there is less time involved cleaning the block/footing junction (excavators don't give us much room, so cave-ins or heavy rain can be a problem....4)Allows the space inside for gravel backfill, so capillary action is a non-issue. Disadvantages 1) the stepping up part if not backfilled, and 2) the lumber.....hauling it, storing it, replacing it......really not a lot of negatives. Plus, when you do your own footings dak, you can get them RIGHT!! I realize some jobs the mason doesn't do the footings, but I prefer to do my own....
| To all The Newbies Starting Up Their Own Business | dirt diggler | General Discussion | 53 | 04-27-2011 07:21 PM |
| Need help with college project! | CMstudent | General Discussion | 23 | 02-18-2009 10:31 AM |
| Bid low on current project what to do ? | boston 08 | Business | 48 | 11-16-2008 01:58 AM |
| Project Manager/Project Engineer | ComConRecruiter | Help Wanted or Looking For Work | 0 | 03-28-2007 03:42 PM |
