Newby With A Head Scratcher
Old 12-03-2008, 06:01 PM   #1
joe dirt's Avatar
Trade: Renovations
Hi all, first post , like most I need help.
I am building a staircase out of metal, the treads (2" angle iron with thin sheet steel skinning the inside bottom) are to be filled to 3/8" from top with concrete and finnally ceramic tile on top.
I require the cement to be light in weight (45 treads lots of weight),,,,,
any ideas ?????
Thanks Joe Dirt
PS metal work is up , no turning back now
joe dirt is offline
Old 12-03-2008, 06:18 PM   #2
Professional Instigator
rbsremodeling's Avatar
Re: Newby With A Head Scratcher
Use Light weight concrete.
What are you confused about?
rbsremodeling is offline
Old 12-03-2008, 08:55 PM   #3
artisanstone's Avatar
Trade: Stonemasonry
You have 45 treads on a single run??
artisanstone is offline
Old 12-03-2008, 09:32 PM   #4
joe dirt's Avatar
Trade: Renovations
Lightweight concrete eh! I have been loosing sleep over the weight issue, great.
the pour will be 1.75" thick, should I re-enforce with mesh?
45 treads, 3 runs. When I figure out how to post pics, I will.
joe dirt is offline
Old 12-03-2008, 09:37 PM   #5
Bodger's Avatar
Are you also setting the tile? If so, you should know what to put in the substrate as far as reinforcment.
If not, let the tiling contractor guide you or even better, include it in his quote and let him do the concrete so there aren't any surprises when he gets there.
Best of luck, sounds like a lot of stairs.
Post a pic.
Might even be a good idea to run the numbers by a structural engineer if you're losing sleep about the weight issue.
Bodger is offline
Old 12-03-2008, 09:45 PM   #6
concretemasonry's Avatar
Trade: Masonry consultant
You probably will not be able to buy real lightweight concrete in such a small quantity.
Lightweight concrete is less than 115 pounds per cubic foot. Normal concrete is about 150 pounds per cubic foot. - That is about a 25 % weight savings.
Dick
concretemasonry is offline
Old 12-03-2008, 09:47 PM   #7
joe dirt's Avatar
Trade: Renovations
I'm doing all the work. I asked about the mesh ( I will install) because I don't no the characteristics of lightweight concrete, never used it before.
The stair design is stamped by a structural eng. , no spec on the concret though.
joe dirt is offline
Old 12-03-2008, 10:09 PM   #8
Tscarborough's Avatar
Check code on using pans. You may be better off buying precast concrete treads.
Tscarborough is online now
Old 12-04-2008, 05:05 AM   #9
Trade: Stonemasonry
The stairs I've seen like this were designed to be filled with floor mud, not concrete. They usually have lath or wire mesh tack welded to the inside of the pan area. If they are engineered, I wouldn't worry about the weight.
Old 12-04-2008, 10:41 PM   #10
CJKarl's Avatar
Trade: Masonry
I did something smaller. Just used bluestone, worked out great.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Turbo Power head (skid steer) rotarex Tools & Equipment 7 11-28-2008 11:50 PM
Exp gc w/crew and subs head 2 gal/hou cmiller Help Wanted or Looking For Work 0 10-27-2008 01:31 PM
I'm so sick of beating my head against the wall dreamz General Discussion 7 09-15-2008 12:25 PM
Service Entrance Cable without the service head Magnettica Electrical Picture Post 11 09-01-2008 09:35 AM
Tape tech 3" angle head problem. Help! dryrocker27 Drywall 16 12-10-2007 11:49 PM
