Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Masonry
Old 02-21-2009, 02:01 PM   #1
tile designer
MattCoops's Avatar
Need help building 3' cement halfpipe skateboard ramp
Got the ok from the wife that I can build a halfpipe in the back yard (inside the wooded area). Already got the area cleared out.
I want to build a 3' high halfpipe. I want it 12' wide and 20' long (that's with 2 1/2' decks).
I know how to build the flat. But have no idea how to curve the transitions.
I want steel pipe sections for the "grind" rail at top of transition.
How would I mud the curves?
I got to get this done before she finds out I will die on this thing and shuts down operation.
MattCoops is offline   Reply With Quote
Old 02-21-2009, 02:06 PM   #2
IHI
IHI's Avatar
Plywood forms braced to helll abd back and a ubber dry pour. just have your grind rail pre cut, i'd weld some sort of j bolt of bolts on the back side so the mud grabs hold of it so it cant be ripped out.
IHI is offline   Reply With Quote
Old 02-21-2009, 02:13 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
http://www.rickdahlen.com/hpplans/plans.html
http://www.rickdahlen.com/hpplans/Halfpipe.pdf
http://www.rickdahlen.com/hpplans/6ftpipe.pdf
http://www.xtremeskater.com/projects/Bobby.html
mickeyco is offline   Reply With Quote
Old 02-21-2009, 02:22 PM   #4
tile designer
MattCoops's Avatar
I was thinking cinder block stacks with rebar on top of footing to create 3' high x 2 1/2' long x 12' wide section on both ends of level slab (for the flat). Then use chicken wire for the curve.
Could this work?
mickey, those plans would be great if this was a wood ramp. But I want it to survive rain and ice.
Old 02-21-2009, 02:30 PM   #5
Handle It!
MALCO.New.York's Avatar
No cement. Marine plywood.
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is online now   Reply With Quote
Old 02-21-2009, 02:35 PM   #6
tile designer
MattCoops's Avatar
I'd like to do it in cement. It's less maintanence when done.
The wife is starting to say wood. So if she wants me to take it down there is no jack-hammering.
Old 02-21-2009, 02:46 PM   #7
tile designer
MattCoops's Avatar
I built a grind box out of wood that was half rotted from a shower demo we did a couple weeks ago. Just cut off the rot and mickey-moused it.
The top is 3/4" OSB with primed luan over it. I took an old piece of angle iron and countersunk holes for attaching.
I'll have to upload it to YouTube
Old 02-21-2009, 02:51 PM   #8
Handle It!
Plywood is much more forgiving when it meets the face, elbows, palms, knees, hip-bones and Occipital Bones.
It ONLY makes sense!!!!
Old 02-21-2009, 05:39 PM   #9
Sean
SLSTech's Avatar
I have to agree with MALCO - except the top layer is masonite
Try this link & go bigger
http://skateboardpark.com/rampplans/...ramp_plans.htm
SLSTech is offline   Reply With Quote
The Following User Says Thank You to SLSTech For This Useful Post:
MALCO.New.York (02-21-2009)
Old 02-21-2009, 05:49 PM   #10
Handle It!
Masonite is perfect! As long as the Grind Rails are Metal.
Old 02-21-2009, 06:16 PM   #11
Bunny by Malco - NY
Chris Johnson's Avatar
Trade: ICF Construction
Hey, dig in the ground and have the Gunite guys show up.
If the wife yelps too loud fill it with water and call it a day
Chris
Chris Johnson is offline   Reply With Quote
Old 02-21-2009, 06:20 PM   #12
Mellison's Avatar
Trade: Home Improvement General Contractor
I had a half pipe in my drive way many years ago.
Actually it was two quarter pipes seperated by the drive way. they were built by me and my friends several years before I got paid to pick up a hammer. No masonite just three pieces of plywood. All day long you would here bump, bump bump......bump bump bump. Needless to say nobody got air.
We stole all the lumber and nails from a houses under construction. For the deck we used what I later learned were plywood forms. We had no idea why they were so slippery.
I remember this old Italian guy driving into my driveway yelling at us because we stole his forms.
Hope this helped.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline   Reply With Quote
Old 02-21-2009, 06:22 PM   #13
Handle It!
Dual purpose "Hole-in-da-Ground".
Smart!!!
Old 02-21-2009, 06:22 PM   #14
Mellison's Avatar
We nailed PVC for the coping.
Boy we were such A$$ holes.
Old 02-21-2009, 06:24 PM   #15
EPD
EPD's Avatar
Trade: Carpentry/Contracting
i built the exact same size one when i was fourteen, four foot walls though, put it on wheels so we could move it to cut the grass.... it lasted 4 years in my yard , tarped in winter and i sold it for 800 to a local kid, who still used it he redecked it recently
one time my dad put it on a trailer and towed it down the road for canada day parade with me and my friends riding it ,
the good old days!
EPD is offline   Reply With Quote
Old 02-21-2009, 09:42 PM   #16
tile designer
MattCoops's Avatar
There's a local skate park here in Charlotte but the moms look at me like I'm a child molester.
Skateboarding helps relieve some of the stresses at work. If I fall down and go boom sometimes it only makes me smile bigger. As long as the "digger" don't break any bones all is well.
Tampa, FL. Concrete Forklift Ramp Needed phattractor Help Wanted or Looking For Work 0 02-10-2009 02:26 PM
Joasis (and others) how much would this building cost in your area? Mike Finley Construction 8 09-15-2008 02:51 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
Certified Green Building Professional Training CatAlii Green Building 6 05-11-2008 03:20 PM
Nobody Wants to bid Deutsche Bank Building Now Wolf Demolition 2 08-26-2007 02:37 PM
