Trade: Outdoor D/B
Need To Build Up Slab 3.5"
I have a job I need to build up the height of an existing slab 3.5" then veneer pattern bluestone over it. Due to the access/finshed backyard pulling the slab out is not an option. What's the safest way to make up that height. Area is about 60sqft.
Re: Need To Build Up Slab 3.5"
Pour 3 1/2" of concrete on top of the existing would be the easiest. If you were worried about crack migration from the underlying slab, isolate with plastic, sand, foam, or a combination of those. Sixty square feet isn't much, why can't you demo? I've demo 'ed slabs in the middle of offices, on the 19th floor of 40 storey buildings. Do a saw cut, hammer and chunk the pieces out. Put in new compacted gravel, and then a high quality concrete.
Pompass Ass
Just pour or pump 4,000 psi concrete on top of the existing slab, no reason to remove it, you could put bonding agent on top of the old slab first, won't hurt but not necessary.
| Installing a Door Slab | CookeCarpentry | Finish Carpentry | 62 | 07-11-2010 08:23 AM |
| granite slab handling | archibaldtuttle | Kitchens & Baths | 3 | 10-12-2009 08:25 PM |
| Slab question | J S Machine | Masonry | 6 | 10-01-2009 12:10 PM |
| Walkout basement: Pavers on a slab? | bert0168 | Masonry | 12 | 08-12-2009 06:52 PM |
| GCing a garage build for a previous customer question about cost of slab. | al10fred1081 | Masonry | 4 | 12-03-2008 10:03 PM |
