Trade: Masonry
Mortar Removal On Aluminum
Hi everyone,
Is there anyway to remove mortar from aluminum? I have atrium doors with aluminum flashing where mortar has dried and hardened. |
Re: Mortar Removal On Aluminum
WD-40 and carefully scrape it off.
Caution: Mortar cleaners contain acid and will react with the aluminum. |
Trade: Masonry
Maybe some OOOO steel wool. You may have to rub down the whole piece so it all matches when your done.
Trade: Masonry
I will try the wd40 method first.
Steel Wool? You dont think that will strip/discolor the aluminum? |
Trade: Concrete, masonry & excavation
I Am pretty sure that once you remove the mortar the aluimium will allready be stained or hazed over. I ran into this proble with an aluimnum store front on a post office had the replace the whole thing.
#6 | |
Trade: Masonry
Re: Mortar Removal On AluminumQuote:
yes |
#7 | |
Trade: Masonry
...and yes |
Re: Mortar Removal On Aluminum |
General Contractor
Trade: Construction Management
Back charge the morter monkey .
It's toast.
DECOSnowRemoval&IceControl Serving Delaware County & Philadelphia Pa 610 457-9721 |
Trade: Masonry
Just remember, blue painters tape is your friend.
| going rate for tile and carpet removal | oldglorydev | Flooring | 18 | 09-21-2008 02:26 PM |
| 1st Row of Bricks on Lentil Dry, In Mortar, or Either? | TomBrooklyn | Masonry | 16 | 08-30-2008 04:01 PM |
| aluminum wire | darren | Electrical | 10 | 08-30-2008 03:56 PM |
| Mortar Bedding for Stone on Concrete Question. | lukachuki | Masonry | 10 | 05-26-2007 10:09 PM |
| Changing mortar color? | kcrossley | Masonry | 1 | 12-17-2006 01:44 AM |
