Mortar For Firebrick
Old 11-11-2005, 05:53 AM   #1
54roadmasters's Avatar
Trade: Landscaping
Hey guys,
I am building a fire pit out of granite cobblestone. It is about 20" high, 60" OD. I will fill all but the top 8" with gravel for drainage. Question: Should I use fire brick on the inside for say the last 12 inches or will the cobblestone be OK to leave exposed. Either way, do I need to use a special mortar, mix standard mortar differently or what for the joints of the cobblestone and firebrick?
54roadmasters is offline
Old 11-11-2005, 11:18 PM   #2
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
Rewards Points: 2,000
Re: Mortar For Firebrick
Originally Posted by 54roadmasters
Hey guys,
We used to do fireplaces with fire brick fire boxes 20 years back. We just made the regular motar mix richer with portland cement. Not quite a goo but close. If i was going to use a premixed mortar I would add portland for sure.
K2 is offline
Old 11-11-2005, 11:29 PM   #3
Mason
FireballBrick's Avatar
Trade: Masonry
Rewards Points: 25
Send a message via AIM to FireballBrick
Using the cobblestones may be ok, but I wouldn't put my life on it. Regular brick and some rock have air pockets in them that will expand and literally pop when heated. My dad built a half-assed grill out of concrete pavers, and they have done well, and they are directly lining the firebox. I don't think I would use it as a firebox on a professional job though. Like previously posted, you should not use regular mortar for anything involved with the heat. It simply crumbles when it is exposed to extreme heat. Have you seen the movie Ladder 49? Remember when he digs throught the brick wall with his bare hands? I said no way! My buddy who brought the movie over is a firefighter and told me that it really could happen, that brick walls cave in during fires all the time. Anyhow, back to your question, at your brickyard or supply, they should sell a mortar specifically for high heat areas. Call your brick supplier, they will tell you where to find it in your area.
FireballBrick is offline
Old 11-12-2005, 09:51 AM   #4
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
Granite is pretty dense and solid but still not as good as a firebrick. For mortar I would think fireclay would be your best bet.
6stringmason is offline
Old 11-12-2005, 10:03 AM   #5
JustaFramer's Avatar
Trade: Exiled For Life
I wonce used a 3 hr fire rated mortar to plug a hole in a fire wall. Got it from McMaster-Carr.
There was a few ways to fix this wall one was to pull out the walk in Freezer The other one was to build a bump out So we settled on plugging with the mortar and fire rated caulk. Big hole and multiple conduit lines run.
All I know is the building inspector passed it.
JustaFramer is offline
Old 11-12-2005, 10:34 AM   #6
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Rewards Points: 250
Fire brick = fire clay. Either the dry clay you mix yourself, or that "sairset material in the gallon cans. The brick and clay have essentially the same coefficient of expansion so there is no separation. Do not use a portland mix as the joints will begin to crumble out.
A lot of granite carvers use a propane torch to pop the surface off. The same thing will happen in your firepit if you don't use the fb liner. Make sure you leave a space between the disimilar materials because they too will expand at different rates. resulting in cracked work. ( but what the heck, it's probably going to crack anyway )
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Colored Mortar ophnurse Masonry 8 02-14-2009 08:50 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 09:09 PM
brick and mortar jshuatree8 Masonry 6 04-25-2007 08:37 PM
Changing mortar color? kcrossley Masonry 1 12-17-2006 12:44 AM
Mortar too white locofoco Construction 2 01-29-2006 04:31 PM
