Mortar Colorant
Old 12-11-2017, 02:53 PM   #1
5awyer5's Avatar
Rewards Points: 4
Mortar Colorant
I'm installing an exterior gold quartz flagstone (irregular) walkway. It's light gray in color with a gold shimmer. What mortar colorants have you used and recommend? I'd like for the mortar to be charcoal gray once dried, without using a sealer. Should I use a black colorant knowing it will fade over time?
5awyer5 is offline
Old 12-11-2017, 05:29 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 5,360
Re: Mortar Colorant
Yes, the black pigment gives you dark gray when used in lesser concentrations. Black will also fade to gray eventually even if used at full strength.
You'll be using very little pigment to move it to dark gray...If you give me your mix size...and you're using powder oxides, I can steer you in the right direction in terms of how much to add...e.g mix ratio and actual volume you'll be mixing at a time.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
brickhook (12-12-2017)
Old 12-12-2017, 06:19 AM   #3
PaulFalls44's Avatar
Trade: Electrical
Rewards Points: 42
Re: Mortar Colorant
I agree with the above comment
PaulFalls44 is offline
Old 12-12-2017, 07:09 AM   #4
Tscarborough's Avatar
Rewards Points: 1,406
Re: Mortar Colorant
If you use jet black it will "fade*", but using super iron black or other oxide pigments will not fade much over a very long time.
*It doesn't technically fade, the particles are so small they wash out of the mortar.
Tscarborough is offline
The Following 3 Users Say Thank You to Tscarborough For This Useful Post:
concretemasonry (12-15-2017), fjn (12-12-2017), Texas Wax (12-12-2017)
Old 12-12-2017, 02:48 PM   #5
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,040
Re: Mortar Colorant
Using sand like this helps.
https://www.aboutroofing.com/black-s...SABEgLhz_D_BwE
or this
http://www.specialistaggregates.com/...8ec215410d97c5
stuart45 is offline
The Following User Says Thank You to stuart45 For This Useful Post:
fjn (12-12-2017)
Old 12-12-2017, 05:41 PM   #6
fjn's Avatar
Trade: mason
Rewards Points: 9,134
Re: Mortar Colorant
Originally Posted by stuart45 View Post
Or this,one of their plants is less then 10 miles from me.
https://www.ebay.com/i/253277178857?chn=ps
fjn is offline
Old 12-12-2017, 05:52 PM   #7
fjn's Avatar
Trade: mason
Re: Mortar Colorant
Here is the parent company web site.
http://www.blackbeautyabrasives.com/...-questions.php
fjn is offline
Old 12-14-2017, 09:08 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,347
Re: Mortar Colorant
Maybe leave joints raked back with bag run natural color mortar, then grout with a colored floor tile product?
Fouthgeneration is offline
Old 12-15-2017, 07:32 PM   #9
5awyer5's Avatar
Rewards Points: 4
Re: Mortar Colorant
Unfortunately I don't have sand like that available locally. In the past I've used the colorants available at local big box hardware stores, with mediocre results. This is a relatively big project. Is there a brand I can purchase online that's better quality than Home Depot, Lowe's, etc?
5awyer5 is offline
Old 12-15-2017, 07:39 PM   #10
fjn's Avatar
Trade: mason
Re: Mortar Colorant
Where are you located ? Here is a list of their locations.
BLACK BEAUTY® Locations
Alabama, Satsuma
240 Baldwin Road
Satsuma, AL 36572
(800) 731-7982Call: (800) 731-7982
Florida, Tampa
5950 Old 41A Hwy
Tampa, FL 33619
Illinois, Pawnee
226 East 1640 Road
Pawnee, IL 62558
(217) 237-4335Call: (217) 237-4335
Illinois, Pekin
13090 E. Manito Road
Pekin, IL 61554
(309) 347-1962Call: (309) 347-1962
Indiana, Gary
7100 West 9th Avenue
Gary, IN 46406
(219) 944-6250Call: (888) 733-3646
Kansas, LaCygne
East 2150 Industrial Blvd
LaCygne, KS 66040
(913) 757-4561Call: (888) 733-3646
Kentucky, Drakesboro
9001 State Rte 176 East
Drakesboro, KY 42337
(270) 476-8020Call: (270) 476-8020
Louisana, Baton Rouge
12001 Leisure Road
Baton Rouge, LA 70807
(888) 733-3646Call: (888) 733-3646
Maryland, Baltimore
608 Folcroft Street
Baltimore, MD 21224
Missouri, St. Louis
4300 Planned Industrial Street
St. Louis, MO 63120
(901) 789-0700 or
(888) 733-3646
New York, Buffalo
2769 Broadway Street
Cheektowaga, NY 14227
Ohio, Gallipolis
5486 State Rte 7 North
Cheshire, OH 45620
(304) 845-0211Call: (304) 845-0211
Pennsylvania, Philadelphia
905 South Port Road
Fairless Hills, PA 19030
(215) 295-8675Call: (888) 733-3646
Tennessee, Memphis
2170 Plant Road
Memphis, TN 38109
901-789-0700
Texas, Houston
13040-A Market Street
Houston, TX 77015
(800) 731-7982
Texas, Rockdale
FM 1786
at Alcoa Sandow Works
(512) 595-2860
(512) 430-2631
Fax: (813) 677-9160
Utah, Salt Lake City
658 South 4050 West
Salt Lake City, Utah 84104
(888) 733-3646
Virginia, Virginia Beach
2429 Ferry Road
Virginia Beach, VA 23453
West Virginia, Moundsville
Route 2 South
Moundsville, WV 26041
Sitemap
Cookies & Privacy Policy
Terms and Conditions
Harsco-m Homepage
© 2017 Harsco Minerals International
fjn is offline
Fouthgeneration (12-15-2017)
Old 12-17-2017, 10:46 AM   #11
Re: Mortar Colorant
Black Beauty/Dakota Black/coal slag are also the best material to sand in interlocking pavers. It is sharp and does not wash out like normal sand, plus, being black, it looks better with most colors of pavers.
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
fjn (12-17-2017), Fouthgeneration (12-17-2017)
Old 12-17-2017, 11:26 AM   #12
fjn's Avatar
Trade: mason
Re: Mortar Colorant
Also,in 1980,I needed to place a large volume of fill within the confines of an office building we were constructing. Being very close to one of H.B Reeds plants,I thought their product could answer the need. I was quite fortunate,taking a sample to a local engineering firm for compaction testing,the guy I talked with said We can run a test (like we have done hundreds of times,or you can just believe what I'm telling you. He said"in a contained area,it is self compacting ! Huge 'bonus' for the job. Reed only charged a token fee for loading our semi trucks. We just deposited them inside the foundation and called it a day. All 88 of them.!
fjn is offline
Is Hydraulic Mortar All It Claims To Be ? fjn Masonry 12 06-28-2016 06:50 PM
Mortar Colorant Mystery akmountaineer Masonry 11 12-12-2015 02:27 AM
Identifying Lime Mortar. Can it be repointed with Type N? yourfriend Masonry 79 08-21-2013 08:07 PM
Fixing this rock shed topps Masonry 43 02-23-2013 09:56 PM
Roof rafters, floor joists. Wood to mortar contact. Baltimore Masonry 16 08-04-2012 02:58 PM
