Mildew On Brick...
Old 01-16-2008, 03:58 PM   #1
bujaly's Avatar
Trade: Commercial interior super
Mildew On Brick...
I have a customer that has a list full of things to be done around her house, one of which is to clean the brick in the font of the house. It's a small area, around 150 sq. ft of brick patio. In random spots, there is mildew forming. I don't own a power washer, so I don't want to waste money on renting it for just 30 mins of use, PLUS, I do not want to "hurt" the brick. I'd rather just use an agent and scrub the hell out of it. My question is what should I use as far as a cleaning agent is concerned? Remember, I have to get rid of the mildew, PLUS, I want to clean the brick off too. Another concern is all of the shrubbery surrounding the brickwork, I don't want to harm them in the process.
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Old 01-16-2008, 04:16 PM   #2
Tscarborough's Avatar
Re: Mildew On Brick...
Jomax, and make sure everything in the area is thoughly wetted before you srart and rinsed when done.
Tscarborough is online now
Old 01-16-2008, 06:22 PM   #3
bujaly's Avatar
Zinnsser's website only recommends using it on painted brick.. What about using an oxygen bleach based product?
bujaly is offline
Old 01-16-2008, 06:32 PM   #4
I am not familar that.
Old 01-17-2008, 04:24 PM   #5
contractor
tom connelly's Avatar
Trade: power washing - new construction and restoration cleaning
eaco chem makes a product called saferestore with long enough dwell time it kills mildew on the spore level, (most products kill it on the surface level) which means it has longer lasting results guaranteed to keep it gone for at least 3 years under normal conditions. it also does a great job cleaning the brick. its also safe for lots of other surfaces as well. just prewet the shrubs and make sure u do a follow up rinse and you should be fine.
Gutter Clean & Power Wash
Hickory NC
tom connelly is offline
Old 01-17-2008, 04:28 PM   #6
contractor
make sure you prewet the brick as well seeing as saferestore is an acid. basically just make sure you follow the directions. they also have a thickened version as well, it does such a good job you may not even have to scrub. by the way gloves are a good idea too.
Hickory NC
Old 01-17-2008, 04:47 PM   #7
florida girl's Avatar
You could always try baking soda. Very old but effective.
florida girl is offline
Thin Brick, VS Regular Brick Project53 Construction 25 03-11-2010 03:13 PM
Braking metal for a brick exterior? Luke's Dad Windows, Siding and Doors 8 01-07-2007 06:59 AM
wire behind brick hurricaneflyer Electrical 7 11-13-2006 08:03 PM
red brick has developed a white coating wbsbadboy Masonry 4 02-28-2006 09:33 PM
