Masonry Wall With Bedrock Footing...
Old 06-17-2009, 08:00 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
For a project I'd like to build a 3' tall cmu wall and veneer it with cultured stone. Bedrock comes right out of the ground. We can not dig down for a footing. Is it possible to drill rebar into the rock and build right off the rock? This would mean no part of the retaining wall would be belowe grade.
ruskent is offline
Old 06-17-2009, 08:30 PM   #2
Trailer park boy
shanekw1's Avatar
Re: Masonry Wall With Bedrock Footing...
I know a guy who built most of his house that way, right on the edge of a huge rock outcropping. I'm sure glad I was not the guy who did the formwork on that one.
shanekw1 is offline
Old 06-17-2009, 09:37 PM   #3
tgeb's Avatar
I would think the wall would be fine, but....
What will it be holding back?
What will be the spacing of the vertical rebar?
Will you be filling all the cells of the wall?
Have you had an engineer look at it?
I know you will do proper drainage behind the wall so that's not an issue.
Again, most likely it will be fine.
www.gebcon.com
tgeb is offline
Old 06-18-2009, 12:53 AM   #4
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
A retaining wall for bed rock. Hmmm not sure I can see the point, but then again it sure beats watching paint dry.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 06-18-2009, 01:08 AM   #5
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
I have drilled and epoxyied (sp?) many rebars into many bedrocks for ICF work and not had a footing, I would expect this would be the same for CMU's
Chris
Chris Johnson is offline
Old 06-18-2009, 06:25 AM   #6
joe dirt's Avatar
Trade: Renovations
I do it all the time, Drill into the bedrock infront of where the wall is supposed to be, 1' apart, install the rebar in the holes, cut longer then the height of the wall, build the form off this row of rebar. drill more inside the form for rebar, level the original form, fill full of concrete
joe dirt is offline
Old 06-18-2009, 09:37 AM   #7
ruskent's Avatar
Trade: Outdoor D/B
Basically on this property there was a huge bank that was cover in dirt looked bad. So we start clearing the dirt off. We were able to have exposed bedrock 5' tall in some areas. In other areas its only 2' tall. So now we have several feet of dirt we need to retain. I don't have finshed excavation pics but here is a pic from day 1.
Masonry wall with bedrock footing...-11qhorserock-027-p-.jpg   Masonry wall with bedrock footing...-11qhorserock-029-p-.jpg
ruskent is offline
Old 06-18-2009, 09:38 AM   #8
ruskent's Avatar
Trade: Outdoor D/B
As we drove furthur down the road there is less and less bedrock.
ruskent is offline
Modifying a load bearing wall. wall2wall Framing 85 01-09-2009 10:57 PM
Retaining Wall Delima - Please help nerd04 Landscaping 5 07-29-2008 10:58 PM
Neighbors wall allowing drainage into my yard Team Scream Masonry 20 11-04-2007 02:05 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
