Mason Or Cold Chisel! What Is The Difference?
Old 09-19-2012, 03:01 PM   #1
sleeper's Avatar
Trade: electrical
Rewards Points: 99
I just came from Home Depot and they have mason, cold, electrical, brick and a flooring chisels. They all looked alike and asking about the same amount. Can someone tell me what the difference is because I just don’t see it?
And whats even crazier is that I've been a Electrician for 40 years and I've never even heard of a "electricians" chisel.
sleeper is offline
The Following User Says Thank You to sleeper For This Useful Post:
Jaws (09-19-2012)
Old 09-19-2012, 03:22 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 342
Re: Mason Or Cold Chisel! What Is The Difference?
An "Electrician's Chisel" is generally a screwdriver...
A Cold chisel usually has two bevels on the cutting end unless it is a "Flat Chisel".
A Mason's chisel has a single bevel and come in a variety of widths depending on the intended use. A "Brick Chisel" is a type of Mason's chisel, usually wide.
I think......
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
Inner10 (09-19-2012), Jaws (09-19-2012), MAULEMALL (11-30-2012), sleeper (09-19-2012)
Old 09-19-2012, 03:30 PM   #3
The Sheriff
Jaws's Avatar
Rewards Points: 4,148
The electrician I used for years, before we had to part ways, used a grinder and cold chisel all the time when putting GFIs in rock for me. He would flay the rock out with a chisel around his cut out and make it look more natural.
Other than that, never seen an electricians chisel. I know an elecricians saw is a sawzall. Lol
Jaws is online now
The Following User Says Thank You to Jaws For This Useful Post:
Old 09-19-2012, 04:14 PM   #4
sleeper's Avatar
Trade: electrical
Rewards Points: 99
Originally Posted by griz View Post
An "Electrician's Chisel" is generally a screwdriver... '''
LOL I think you are on to something there, because I have used my screwdriver, but only when nobody was looking.
Well I have had what I always thought was a masons chisel that I would use to on sloppy stucco jobs to get my outlets and cover on and I have a cold chisel that I use for metal. Iíve always identified them by type of metal they were made of. My metal cold chisels seem to be a harder steel and usually shinny, but not always and my mason chisels are a duller and I believe but not sure are softer because they never last very long.
I compared all the chisels at Home Depot and except for the length and the width they had exactly the same double bevel point.
sleeper is offline
Old 09-19-2012, 04:22 PM   #5
DavidC
DavidC's Avatar
Rewards Points: 2,006
It's been mostly forgotten over time. But an electricians chisel predates the invention of transformers. Goes back to the days when the higher voltages had to be knocked down manually.
Good Luck
www.CookContractingLLC.com
DavidC is offline
The Following User Says Thank You to DavidC For This Useful Post:
Old 09-19-2012, 04:28 PM   #6
Tscarborough's Avatar
Rewards Points: 1,402
Cold chisel, electricians chisel=made for metal.
Masons chisel, brick chisel, flooring chisel=made for stone, mortar, concrete, etc.
Different tempering.
Tscarborough is offline
The Following 3 Users Say Thank You to Tscarborough For This Useful Post:
concretemasonry (09-19-2012), Rich D. (09-20-2012), sleeper (09-19-2012)
Old 09-19-2012, 04:35 PM   #7
sleeper's Avatar
Trade: electrical
Rewards Points: 99
Good Luck
Well I guess the next time I'm over there, I'll have to pick one up just so that I can truly say I'm an electrician
sleeper is offline
Old 09-19-2012, 04:36 PM   #8
sleeper's Avatar
Trade: electrical
Rewards Points: 99
Aw yes that's what I was trying to think of thanks
sleeper is offline
Old 09-19-2012, 04:36 PM   #9
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I have a dozen masonry books (well maybe 3 or 4) that refer to using cold chisels. As for edges and bevels, there are dozens of shapes (at least) for different applications. I own at least 20 differently shaped and sized chisels, some I use daily, others only a few times. To say a masons chisel would be like saying a carpenters saw
I doubt there's much difference in those chisels. as Tscar said maybe a bit in tempering but I think the difference would be negligible
www.dominionmasonry.ca
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
Old 09-19-2012, 09:18 PM   #10
You can use metal chisels on masonry, just not the other way around.
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
Old 09-19-2012, 09:44 PM   #11
sleeper's Avatar
Trade: electrical
Rewards Points: 99
I was thinking about this and I seem to remember destroying a chisel on metal when I was younger, but I donít remember the details. It might have been my dadís chisel when I was a teen.
sleeper is offline
Old 09-19-2012, 11:11 PM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,560
I did the same...that's called a wood chisel.
Inner10 is offline
Old 09-20-2012, 09:17 PM   #13
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Now its called a beater chisel
ďThe bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.Ē - Aldo Gucci
Rich D. is offline
Old 09-20-2012, 09:44 PM   #14
chewy's Avatar
Trade: Electrical Apprentice and Data Technician.
Rewards Points: 1,208
I use a cold chisel all the time for cutting mild steel cable tray and components.
An Electricians chisel when I think of it is a brick bolster the width of a box hole they use on masonary and rough cast in Europe.
chewy is offline
Old 09-20-2012, 10:25 PM   #15
sleeper's Avatar
Trade: electrical
Rewards Points: 99
I did some searching on line to get more info on it and found one on Amazon that was pretty reasonable. It also gave this description ďElectricians Chisels are used for rough cutting and trimming of wood, wallboard and masonryĒ so I guess itís more of a multitask chisel. I personally would never use it on wood, but thatís probably from my woodworking background. As an electrician I always carried a wood chisel and a cold chisel in my tool bag.
Iím also a collector of tools and I like having complete sets of every trade. Well that is hand tools because some specialized tools are way too expensive for me to collect. So anyway I ordered the one from Amazon to add to my collection.
sleeper is offline
Old 09-21-2012, 12:13 AM   #16
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
We call those chiselzall.
jkfox624 is offline
The Following User Says Thank You to jkfox624 For This Useful Post:
parkers5150 (09-23-2012)
Old 09-21-2012, 02:14 PM   #17
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Originally Posted by chewy View Post
brick bolster
Nice, I don't hear people talking about bolsters too often. Nice to see someone else using the term.
dom-mas is offline
Old 11-30-2012, 12:09 AM   #18
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,314
They're called cold chisels because they are cold forged. Before sawzalls metal pipes were often cut with chisels. I did it once, before I owned a sazall. It actually worked really well. Simply beat a circumference around the pipe two or three times.
Metro M & L is offline
Old 11-30-2012, 12:24 AM   #19
chewy's Avatar
I believe and could well be wrong that a blacksmith uses hot chisels for hot metal and cold chisels for cold metal, its not named after the manufacturing process.
chewy is offline
Old 11-30-2012, 09:40 AM   #20
sleeper's Avatar
Trade: electrical
Rewards Points: 99
Well 40 years ago and I do not remember much of any of it, I went to school a couple of years to be a machinist. We had to learn a little bit of metallurgy and the difference between hot rolled and cold steels before actually using the machines and I never heard of that before. I believe the cold chisel is just the type of steel itís made of and not how itís used. I ended up in construction and never did actually work as a machinist.
sleeper is offline
Going great until this happened ECSOWNER Low Voltage 44 11-08-2013 08:08 AM
Cold floor Old Truck Flooring 8 01-25-2011 11:28 AM
Cold Jet/ColdJet 250-FP? ERAD_DIB Sandblasting 12 01-17-2011 11:29 AM
Hot water coming out of cold side Eric K Plumbing 12 06-29-2009 08:43 PM
