Lock Hasp Into Old Soft Brick.
Old 12-14-2017, 01:44 PM   #1
VinylHanger's Avatar
Rewards Points: 7,580
I need to install a lock gasp I to some old brick. Unfortunately it is right on a corner. I don't want to damage it, or have it damaged too much If someone wants to pull or pry on it.
What are the best fasteners toggles/lag shields, etc. I picked up some of these, but I'm not sure if pounding the pin in is a good idea.
This is the corner. I need to go through the stucco then into the brick. The mortar is a super soft sandy mix. I could rub it out with my finger.
VinylHanger is offline
Old 12-14-2017, 02:04 PM   #2
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 608
Re: Lock Hasp Into Old Soft Brick.
Those anchors you have are great but probably not for that situation. Safest bet is tapcons. They will strip out though if you're not real careful about putting them in. May take a little threading in and backing out. Epoxy anchors would work too.
artisanstone is online now
Old 12-14-2017, 03:54 PM   #3
I'm thinking epoxy may be my best bet. Tapcons are my go to in most situations, but I don't want them to be able to be backed back out. maybe tapcons with epoxy in the hole?
The Following User Says Thank You to VinylHanger For This Useful Post:
SmallTownGuy (12-18-2017)
Old 12-14-2017, 04:11 PM   #4
Trade: Stonemasonry
Rewards Points: 608
belt + suspenders
The Following User Says Thank You to artisanstone For This Useful Post:
VinylHanger (12-14-2017)
Old 12-15-2017, 07:01 AM   #5
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,040
Can you fix a 1/4 inch steel plate to the wall first, and then drill through for the fixing?
stuart45 is offline
Old 12-15-2017, 07:47 AM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,458
That looks really crumbly, try a tapcon, if it doesn't bit put a zip tie tail in the hole.
Inner10 is online now
Old 12-15-2017, 09:29 AM   #7
Railman's Avatar
Trade: Railing
Rewards Points: 459
Flip hasp by removing pin, & rotating mount side so it is behind wall/door. Reinstall pin w/ locktite, epoxy, JB weld, & peen over end asap. before cure.
Then use your hammer drive fastener so it expands up & down. The brick will be harder than the mortar, & will not break down as easily.
You could go one step farther by adding the hasp onto a steel plate inside storage area.
I'm thinking the hasp will only do so much anyway, & regardless of what you install, will have limited security.
Railman is offline
Old 12-15-2017, 10:47 AM   #8
it is just to keep idiots out. There isnt really any reason for people to go back there, except to dump crap, or take a dump I suppose. It's also in a semi exposed area.
Old 12-16-2017, 10:59 AM   #9
I ended up putting the hasp on the sidewall with 1/4 inch tapcons and a small but of epoxy on the threads, then put epoxy in the Philips slots for fun.
This made it so if it is pried on, it should only damage the wood and not the brick. Any other way, and you could smack the hinge with a hammer and bust it out of the brick.
Old 12-17-2017, 10:44 AM   #10
Tscarborough's Avatar
Rewards Points: 1,406
Lead anchors.
Tscarborough is offline
Old 12-18-2017, 03:57 AM   #11
Now you tell me. :grin:
Old 12-18-2017, 06:05 AM   #12
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,878
My go to for epoxy in those situations is JB Weld.
I usually carry a stick of that quick-set of Plumbers Epoxy in the truck too.
It can be formed, shaped, filed.
SmallTownGuy is online now
Old 12-18-2017, 05:27 PM   #13
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,341
If you can access the back side of the jamb, install two angle irons over the corners with holes drilled for two or three galvanized/S.steel threaded rod/ long carriage bolts. Paint to match brick, maybe do the hinge side......
Weld on hasp hardware...
Maybe a broken/faux/ or real video camera surveillance?
Fouthgeneration is online now
Setting a wall on Brick Roll Lock? SailingandSuch General Discussion 11 11-23-2013 10:30 PM
brick chimney leaking through brick? dave_dj1 Roofing 38 03-30-2012 03:28 PM
removing brick Yersmay Masonry 27 12-24-2011 10:46 PM
Thin Brick, VS Regular Brick Project53 Construction 25 03-11-2010 02:13 PM
Hanging cabinets on old plaster over soft brick Bob H Remodeling 5 07-16-2007 11:46 PM
