Lintel Blocks?
Old 09-22-2017, 01:15 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 96
Lintel Blocks?
I just got a quote for about 20 lintel blocks. 33 something bucks a piece, and a $450 set-up fee.
This is from Basalite.
I said "no thanks, I'll form the bottom of the bond beam".
Do guys not use these anymore? I remember them being fairly common when I was a truck driver for a building materials company in the late '90's.
Delta
I have an Edifice Complex.
Old 09-22-2017, 01:37 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,912
Re: Lintel Blocks?
What do you consider a "lintel block"?
The unit price is high, but the set-up charge is lower than most producers should charge.
Must be an unusual shape unit. The mold costs for most common units could be about $10,000 (new mold).
When I was involved in making and supplying block, we would charge $500 to $1000 per set-up (plant down time) for specialty shape for one job.
We were in the business of making block and selling them to masonry suppliers, contractors and other block producers. - We normally had 1200 different block shapes and weights/materials in our minimum inventory of about 2,000,000 block. We sold 12,000, 000 to 16,000,000 block a year.
I am surprised that Basalite did not have specifically what is required in inventory since they are a good producer.
Dick
concretemasonry is online now
Old 09-22-2017, 01:45 PM   #3
Trade: Builder/GC
Rewards Points: 96
Re: Lintel Blocks?
Yea, I was surprised too, as it was a stock item when I worked at the supply house.
It's just a 8-8-16 closed bottom bond beam.
Since it isn't a stock item, I'm assuming most masons don't use them for door and window openings anymore. Maybe they just form the bottom of a standard bond beam, like I'm going to do. I dunno, I'm not a mason. Just play with it from time to time.
Delta
Old 09-22-2017, 01:46 PM   #4
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 602
Re: Lintel Blocks?
The question is probably very regional. If I say lintel, it's either angle iron or 4x8x xx reinforced cmu's. I'm imagining a bondbeam block with a closed bottom from your comments, but I've never seen one.
artisanstone is offline
The Following User Says Thank You to artisanstone For This Useful Post:
Seven-Delta-FortyOne (09-22-2017)
Old 09-22-2017, 02:08 PM   #5
Trade: Builder/GC
Rewards Points: 96
Re: Lintel Blocks?
Probably. I'll see some angle iron, but because we fill every core here, you need a closed bottom block.
Delta
Old 09-22-2017, 03:30 PM   #6
Re: Lintel Blocks?
It is really a regional problem/situation. To bad the local contractors and engineers do not look at the big picture.
There is really no good reason to grout every core in a block unless you have steel every 8" on center. The grout adds little to the strength of a wall if it is not to grout the steel in place.
Based on looking at masonry construction in 45 countries for the past 50 years or so, the ideal configuration for a block is to have a single core in the center that is formed by 2 cross webs 8" on center with open half cores on the ends.
All webs line up vertically for stack or running bond. It also works perfectly for unreinforced construction. The block meet the ASTM standards for concrete masonry units and they were a little lighter. Many contractors just don't like to handle a block with 2 hands and prefer to pick them up and lay them with one hand on the center web of an old fashioned 2 core 8x8x16 block. We made the double H, 2 web block for 4", 6", 8", 10",12" 14" and 16" walls.
Unfortunately, some contractors never saw the light go on, but that is human and regional situation. Some even like the old fashioned 3 core block. There are many things contractors never bother to think about to make things better, easier and more sensible. - Do you realize that block has a top and bottom?
Dick
Old 09-22-2017, 03:51 PM   #7
SouthonBeach's Avatar
Rewards Points: 989
Re: Lintel Blocks?
In FL we order a lintel beam. It's a precast U shaped beam to span what ever opening we need.
We order it from a different company then the block company.
SouthonBeach is online now
The Following 2 Users Say Thank You to SouthonBeach For This Useful Post:
brickhook (01-06-2018), fjn (09-22-2017)
Old 09-22-2017, 04:39 PM   #8
Trade: Builder/GC
Rewards Points: 96
Re: Lintel Blocks?
I do realize that.
I'm using open end bond beams ( H-block ) for the whole basement, except corners, obviously.
And yes, I have an 8" O.C. rebar pattern for the first 2 feet up, and 16" O.C. above that, except above door and window headers, where it goes back to 8" O.C. Then there is an extra vertical around all openings. And the horizontal pattern is also 16" O.C. (every other course).
And an extra horizontal above all headers.
Hence the closed bottom bond beam.
Delta
Old 09-22-2017, 04:49 PM   #9
Re: Lintel Blocks?
SouthonBeach -
What is the wall thickness and what is the span/length?
What do you use to place the beams?
Some of those can get pretty heavy and hard to handle and set in place.
As block producer, we had some employees "moon-light" that made 4" thick masonry lintels from 3 block to 6 block long. - We had plant fork lifts available and boom trucks for delivery and the "moon lighting" employees were the Laborers union steward and one of our Teamster union truck drivers that worked off the clock. We sold the 4" thick lintels to fireplace contractors and brick/masonry material suppliers. The 8" thick lintels were sold to people that had the ability to handle and set them.
Dick
Old 09-22-2017, 11:05 PM   #10
Rewards Points: 989
Re: Lintel Blocks?
SouthonBeach -
Wall thickness is around 1-1/4" thickening at the bottom with reinforcement bars in it.
Most common is 8" with 6", 10" & 12" available.
They start at 3' long and go up to 24'
For the short ones a few labors will set them, the longest we've hand set was 12'. Had 6 guys lifting it.
Most of the time we will schedule the delivery of the long ones with the masons on site. The delivery driver will set them with the moffit lift for us.
Castcrete is one of the big manufacturers of them around here.
Old 09-25-2017, 05:44 PM   #11
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,223
Re: Lintel Blocks?
If I needed just 20 lintel blocks ( old school U shaped smooth bed bond beams, I 'd just plaster up the bottoms(actually the thicker,smoother 'top' of the C beam) of some California style bond beam units a day or two ahead of the laying of the wall, a chunk of mesh embedded to toughen them up if needed/paranoid....
even using a piece of stucco mesh for grout stop speeds plastering the bottoms later.....If no time left for the day ahead prep.
no charge for that one, 7D-41.
Some company in Florida has hollow galvanized lintel "tubes" 8" x 8" that are design for hurricane code garage doors and patio doors, filled before or after "laying", rebars can be added to raise load caps ratings/ fire rating.
England has sheet metal bent lintels that have been used for decades on veneer construction and 2 wythe masonry residential/ light commercial, with a much lower thermal bridge then conventional U.S style I-beams and base plates. but not for super high loads.
The originals were name catnic lintels for the inventor/manufacturers kids....
Fouthgeneration is offline
Old 10-03-2017, 11:52 PM   #12
dbrons's Avatar
Trade: Masonry
Rewards Points: 606
Re: Lintel Blocks?
out here we just use open end half blocks 8x8x8. If you don't have them you could open up one end of regular half blocks wth a saw and lay them on a 2x8 header with the solid end down. Usually calls for two #5 rebars.
dbrons is offline
The Following User Says Thank You to dbrons For This Useful Post:
Fouthgeneration (10-04-2017)
Old 10-04-2017, 06:24 PM   #13
Trade: Masonry
Re: Lintel Blocks?
In regards to the job site and block plant pre cast lintels, the need for seismic and structural rebars installed through the lintel sections pretty much run them off.
Old 10-04-2017, 06:45 PM   #14
Trade: Builder/GC
Rewards Points: 96
Re: Lintel Blocks?
There's certainly a lot of options. I'll just form the bottom of the bond beam for this project.
I just think it's interesting that no one uses them. I thought they were commonplace.
Delta
Old 01-02-2018, 11:42 PM   #15
MasonrySW's Avatar
Trade: Masonry
Re: Lintel Blocks?
Like everyone has said, there’s several options, but we use lintel block regularly in NV and have seen them used in CA and AZ.
MasonrySW is offline
Old 01-06-2018, 03:12 PM   #16
Trade: Masonry
Re: Lintel Blocks?
I worked on a school that had a continuous Poured ( homemade snap off wire-tied & tapconed to the wall stubs.) raked(average 2 %? ) in one direction wall caps, minimum of 16" in lieu of Normal sawed raked walls ran to the roofing deck for firewalling.
Sadly the architect misfigured the roof drainage slopes in a few sections and the roof deck and steel actually picked several yards of cap beams when the deck was welded 'down'....
You could form a plywood box in place on your piers and pour it as reinforced concrete beams, A few dead legs and lay on the next day, remove the forms when safe--leave the bottom form and dead legs as long as possible( a week plus?)(reuseable??) patch tapcon damage, rub out concrete, fake joints if desired...
71D41: Did you consider over sizing the starter rod a size or two, and elimating the 8" C to C for building ease...
I'll assume you will pour the floor as a wall brace prior to back filling the rebar jungle walls.. other wise you'd need a massive footer.
Also use of 3/16 dura-wall wire in EVERY course improves the walls torsional strength, and might allow the spacing of the expensive horizontal bond beams to be increased to 24" or even 32"
You might consider using a post tension system on the next high side load basement
Cutting house wrap around a steel lintel franzkh Windows, Siding and Doors 13 03-25-2016 10:53 AM
Squash blocks for I-joists woodchuck2 Construction 13 11-22-2013 09:38 PM
Festool MFT/3, or...??? mattsk8 Tools & Equipment 19 04-18-2013 08:14 AM
Steel Tubing Lintel Strength 6stringmason Masonry 16 10-04-2012 09:12 PM
Glass blocks are cracking ToTheT1 Windows, Siding and Doors 16 12-18-2010 10:47 PM
