Trade: Bricklayer
Lime Putty Repointing Pricing Up Question
Just got a job coming up what do most people charge for doing lime putty repointing...there is approximately 160m2.
#2 | |
Re: Lime Putty Repointing Pricing Up QuestionQuote:
Be forwarned that T&M has its own pitfalls as well. The customer will watch you like a hawk watching a rabbit and you will have to account for every move as well as not get paid for the behind the scenes stuff so figure that into your hourly rate.
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! Last edited by lukachuki; 07-26-2007 at 04:49 PM. Reason: added some useless thoughts |
DRIFTWOOD
Trade: GEN CONTR.
Another way to approach this is. suggest doing a few hundred sq. ft ., time and material. At that point You have a good take on the pricing. Leaves the door open for both. Also it sets the standard of workmanship for the rest of the project , no surprises Cheers
Also exactly what do you mean by "lime putty? Some lime mixes require special attention as they don't hydraulically set and if done wrong will end in disaster.
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
Trade: Bricklayer
what i mean is mixing sand with mature lime putty at a 3:1 mix leaving it for about a week and using to repoint a house.
Roo, if you mix mature lime putty with sand at 1:3 and leave it for a week, carbonation will be well under way (it won't work). The proper method is to take Type S dry lime, submerge it in water for at least 3 days(that means gently cover it with water and do not ever, ever stir it), keeping it covered with water at all times (that will create mature lime putty). After that, it will last for months, so long as it is kept covered with water and left alone. Only add sand and expose it to air when you are ready to use it, and only enough for the days usage.
Other than that difference in prep, it is the same as doing any other tuckpointing, and may be priced accordingly (although you might also want to make allowances for misting/shading on the South side of the job in summer. |
Also, unless you are matching an existing historical lime mortar, it doesn't hurt to gauge the mortar with portland cement (only because it is available) to assist with an inital set that allows for easier cleaning and tooling. The ratio is debatable, and will have to be determined on-site, but could range from 1:1:6 to 1:10:5 (cement/lime/sand).
If you are in the UK, disregard everything I have said in both posts and use a premix. |
| Trim Pricing Question | MHMConstruction | Finish Carpentry | 31 | 08-05-2007 09:43 AM |
| New here, pricing question | kreativebass | Carpentry | 2 | 06-29-2007 06:33 AM |
| Not your typical Pricing Question... | realpurty2 | Landscaping | 18 | 05-05-2007 03:35 PM |
| Pricing Question... (Don't Shoot Me) | JNLP | Painting & Finish Work | 6 | 11-08-2006 08:07 PM |
| Pricing question for Baltimore rowhome roof | AmateursGuide | Roofing | 11 | 11-10-2005 03:15 PM |
