Leveling With Concrete
Old 10-01-2008, 11:08 PM   #1
Virg
Virg's Avatar
i have an upcoming project in which i have to level a 20 x 20 room that is way outa level:2". i will have a concrete company bid on it and do it. it is a concrete slab with tile on top of it. im thinking it could be scarified and iron meshed and then poor concrete on top. is this proper?
Virg is offline
Old 10-01-2008, 11:59 PM   #2
JonM's Avatar
Re: Leveling With Concrete
Only 20 x 20...I would get an electric jack hammer and take it out...Then repour the whole thing...
JonM is offline
Old 10-02-2008, 08:43 AM   #3
Ivinni's Avatar
Trade: High Rise Caulk and Insulation
I thought you would get more input from the concrete guys on here, so I didn't chime in. I can tell you that regular concrete used as a topping of anything less than 4" (3.5" nominal) will be a bigger mess thanyou have already.
Find an up to date mix formula for that specific condition (if there is one) or, tear it out and start fresh.
its not going to get better with straps, or new footings or even aroma therapy.
Ivinni is offline
Old 10-02-2008, 09:34 AM   #4
joasis's Avatar
What you are proposing is not a good solution...there are floor leveling products out there, but using concrete isn't an option, even if scarified. Why not do it right and do it once?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 10-02-2008, 10:19 AM   #5
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Don't cap with 2" of concrete. Gypcrete and other floor levellers are available
What is the head room? Can you afford to go up higher or must you break it out and start over?
Chris
Chris Johnson is offline
Old 10-02-2008, 09:01 PM   #6
Virg
Virg's Avatar
plenty of headroom. i didnt realize that pouring over it with concrete would be terrible but now i do. are the floor levelers mentioned worth it if the floor slopes 2". im not trying to be half ass, just trying to learn a little something before i talk to the concrete companies. not to mention not having to tear up all that concrete if there is no need to
Virg is offline
Old 10-02-2008, 09:07 PM   #7
genecarp's Avatar
micro topping
genecarp is offline
Old 10-02-2008, 09:09 PM   #8
genecarp's Avatar
here is one option
http://www.brickform.com/category.php?cat_id=51
genecarp is offline
Old 10-02-2008, 09:33 PM   #9
Virg
Virg's Avatar
that wouldnt work for my situation but that was awesome. that would look great on some basement finish jobs
Virg is offline
Old 10-02-2008, 10:17 PM   #10
buckeyeso2's Avatar
Trade: carpentry
I have capped several different slabs over the years, and so far i don't know of any problems. I have done this on inside and outside concrete. Don't pur the concrete any less than 2" thick. Use a small limestone mix or pea gravel mix, and use fibers. This should work fine for you. If you have the headroom, cap it.
buckeyeso2 is offline
taking a crack at my own concrete work J-Peffer Masonry 9 10-25-2010 06:16 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 09:10 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 05:18 PM
