Trade: masonry
Lead Counter Flashing
hello. i am new to the forum and i need some help. i used to work for a brick/stone mason for about 3 years and i decided to go off on my own (doing mostly stone veneer and walls). i am in the process of building a block chimney in my house and i have a question about the lead counter flashing (on the sides of the chimney). the mason i used to work for would cut the lead at an angle at the roof line...but i have seen some chimneys where the lead bends at the roof line and overlaps onto the shingles...i have even seen some where the lead was tucked under the shingles...my question is what is the best/correct way to "end" the lead counter flashing...cut before the roof, or overlap onto the roof? thanks you...
Re: Lead Counter Flashing
Good question.Perhaps an experienced mason in your area would know.
Trade: Renovations
Counter flashing is better than a single piece that goes from the masonry all the way to under the shingles. IMO. It allows for movement of the house around the chimney w/o disturbing the flashing. So use a lower pan flashing, then step up the sides, then top pan, then come back and counter flash into the masonry.
I wish folks still used lead counter around here. Bends enough to let a guy do a proper flashing job on a re-roof.
| What Internet lead services should do to corner the market | Mike Finley | Business | 45 | 03-26-2010 09:17 PM |
| Yet another thread about lead company | Heritage | Online Leads Services | 9 | 10-13-2007 04:10 AM |
| Step Flashing | Hardibuilt | Roofing | 3 | 05-18-2007 02:08 AM |
| encapsulating lead paint | lornmastro | Painting & Finish Work | 17 | 10-03-2006 09:50 PM |
