Lay N Block
Old 04-08-2007, 03:29 PM   #1
"D"'s Avatar
Trade: carpenter
Lay N Block
what is the average cost to lay a 8" block ? do u charge by the block or base it on the amount of block to be layed, sqft,? .example;20'x20' 4 coarse high, no steps ,staight runs .what is the averge cost ?
"D" is offline
Old 04-08-2007, 04:12 PM   #2
Tscarborough's Avatar
Re: Lay N Block
What is the average cost to nail a 2x4?
Tscarborough is online now
Old 04-08-2007, 04:41 PM   #3
"D"'s Avatar
Trade: carpenter
Re: Lay N Block
"D" is offline
Old 04-08-2007, 06:37 PM   #4
stacker's Avatar
Trade: masonry
Re: Lay N Block
i charge 3 bucks a block(labor).1.00 extra to grout both cells..50 to fill with zonolite.
stacker is offline
Old 03-23-2011, 04:15 PM   #5
allyougottadois's Avatar
Re: Lay N Block
In my neck of the woods a mason is expected to lay min 300 + block a day on a perfect running wall ( corners not included ) The conditions for this is a new block foundation with block delivered into the foundation pit( basement )
If its a below grade off of footer 3' max depth. Then 250 block a day
Rehap is a completely different animal. The fastest mason can only lay as fast as the block is stocked where its easy access for him to maneuver and lay that block..
We usually have 1 or 2 labors for every 4 to 5 masons depending on site condtions.
allyougottadois is offline
Old 03-23-2011, 04:44 PM   #6
Working
Cole82's Avatar
Send a message via AIM to Cole82
Re: Lay N Block
Good thing you dug up this 4 year old thread. I about missed all te usefull info in here.
Cole's Custom Creations
Cedar Rapids, Iowa
What is this "work" you speak of?
Cole82 is online now
The Following User Says Thank You to Cole82 For This Useful Post:
ChristianSmith (03-24-2011)
Cinder Block walls, block filler and a leak...question SeanATL Painting & Finish Work 9 03-09-2009 04:33 PM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Just boguth a new short block for race car:) IHI Off Topic (Non Trade) 4 09-21-2006 09:25 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
