Larger Opening In Cmu Wall
Old 12-13-2017, 09:31 PM   #1
fredbrick's Avatar
Trade: masonry
Hi everyone. I have started a job for a contractor and looking for a bit of advice please excuse my ignorance. Im still a newer journeyman and have mostly worked for someone else or my own smaller jobs. Part of the job entails making a 12' high by 10' wide garage door opening where a 8'x 8' opening exists. It ties into 2 pilasters. I have cut a opening next to the pilaster that has to be removed and built another one at 10'. There are 6 courses of block over the opening including the top course which is a bond beam. I was hoping there were vertical steel grouted over the opening tied into the top bondbeam but there are none. I'm wondering if I can cut a slot the same depth as a bond beam from the existing pilaster (with a epoxied dowel) into my new pilaster that I have left open to receive 2 15 rebars and grout and patch it. Not worried about it being patched up just if it's a dumb idea to cut the sidewall out of 12 feet of a unreinforced cmu wall lol. Thank you.
fredbrick is offline
Old 12-14-2017, 09:56 PM   #2
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,393
Re: Larger Opening In Cmu Wall
If you can patch the Work all you want, cut/ drill Five 2.5" holes every 16" through the wall in about 1/2" higher then where the top of the Lintel, a 8" nominal H beam @ 15 lbs a foot with a 1/4" X 7" X 10' plate stitch welded to the 'bottom' will go.
Insert some heavy duty schedule 80, 2" pipe x 18"+('Needles') through the holes, install dead legs under both sides, demo and install new lintel, lay your soaps, patch and paint, cash the check, PAY your GST..
Around here, in flyover land, a Journeyman whatever has had over 8,000 verified hours working in the trade UNDER the supervision and teaching by at least one qualified J-man.....
I'd strongly suggest a couple hours a week in a library/InterNet and finding a mentor/ Rabbi to further your Masonry skills and Knowledge.
Demoing an opening without a clue on a safe method could get someone hurt badly and maimed for a lifetime.
Shame on the cheapskate that hired you.
Fouthgeneration is offline
Old 12-14-2017, 10:58 PM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,092
Here is 2 9x10 openings that I turned into 12x12s about a month ago... using shoring scaffolding to support the wall above
This one was complicated due to the 8 inch pier and cold joint that the existing wall was sitting on, it wasn’t really tied into the other wall so the first shore was placed close to the corner because it worried me. Bad design and dangerous if a forklift hit that little pier holding the whole wall up
Windycity is offline
The Following 6 Users Say Thank You to Windycity For This Useful Post:
fjn (12-15-2017), Fouthgeneration (12-15-2017), overanalyze (12-15-2017), Rio (12-15-2017), superseal (12-15-2017), Tscarborough (12-17-2017)
Old 12-15-2017, 12:21 PM   #4
fjn's Avatar
Trade: mason
Rewards Points: 8,396
Very well done Windy !
fjn is offline
Old 12-15-2017, 08:13 PM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 4,856
Windy got it right...shoring jacks make it easy peasy!
larger opening in cmu wall-img_0664.jpg   larger opening in cmu wall-img_0604.jpg   larger opening in cmu wall-img_0626.jpg   larger opening in cmu wall-img_0616.jpg
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
fjn (12-15-2017)
Old 12-15-2017, 08:27 PM   #6
fredbrick's Avatar
Trade: masonry
Thanks guys exactly what I ended up doing. Fourth generation I have well over 8000 hours in the trade just have never made an opening in block this large before hence me asking. Thanks
Off Center Bearing Wall Milhaus Framing 2 02-11-2016 05:54 PM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 11:56 PM
Retaining Wall Rebuild Dovetailed Landscaping 22 03-31-2012 09:02 PM
Shoring Exterior Load Bearing Wall for Beam insertion larch General Discussion 4 01-27-2012 07:47 PM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 05:57 PM
