Trade: Outdoor D/B
How To Remove Cement From Cultured Stone?
I'm doing some sub work for a contractor and he would like me to fix a job his retarted mason did. The mason did some cultured stone and it is the worse stone job i ever seen. There is cement all over the stone. Whats the best way to get the cement off. It does not have to be perfect, just better then it is right now. BTW the guy isn't using the mason anymore.
Matt |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: How To Remove Cement From Cultured Stone?
My guess is going to be Muriatic acid unless it eats cultured stone. Is all cultured stone real stone veneer?
Trade: masonry
Its not cement.. its mortar. Just to be anal :P And you dont want to use muriatic. It will eat the color off the cultured and you will have a bigger mess. A good solution is Burnished Stain Remover. A product from SureKlean. It comes in one and 5 gallon jugs and is anywhere from 16-25$ a gallon. It says to mix at 3:1 but for cultured your best bet is upwardsof 6:1. Heres a site with some options for ya. http://www.prosoco.com/ProductList.asp?m=0&i=7
Another reason I start at the top and work my way down when doin cultured stone...less cleaning.
My first attempt at it would be with a pressure washer, 2600 psi or more. But i am fairly good with the PWash.
The PWash should be able to knock off the major mortar. |
Trade: masonry
you dont want to pressure wash cultured stone. The pressure could take some of the color off the stone and you'll be left with white spots that look like block. Cultured stone has to be hand scrubbed with a dairy brush. At least thats the way I was taught and have always done it. On cultured stone the coloring only goes in maybe 1/8". Not too much. Just dyed.
#6 | |
Chief Toilet Mover
Re: How To Remove Cement From Cultured Stone?Quote:
Looks like my first attempt would have ended in doom for me.
#8 | |
Trade: masonry
Doh!
Trade: masonry
i would use a wire brush.NEVER use acid on any precast stone product.depending on the quality of the stone,i would also be afraid to use a pressure washer.(maybe one not so powerfull would work.)
| Cultured Stone | rockbrain | Masonry | 38 | 08-12-2009 10:54 AM |
| cultured stone prices | samiam | Masonry | 9 | 08-13-2007 05:13 PM |
| Looking for Cultured Stone work in NJ | HemiMan2500HD | Help Wanted or Looking For Work | 2 | 03-20-2007 06:58 PM |
| How to get texture in stone cement | carlspackler | Masonry | 3 | 09-16-2006 09:48 PM |
| Cultured Stone | mant | Masonry | 35 | 09-12-2006 07:46 AM |
