How To Lighten Grey Mortar Color
Old 05-28-2012, 10:01 PM   #1
trav26's Avatar
Trade: Carpentry/ General Contractor
Masonry gurus, I am trying to mix some mortar that is light grey in color to match some pool coping. I mixed some txi masonry cement 3 parts sand to 1 part mortar and its not light enough. What is too much sand in the mixture? Can I mix in white portland cement to lighten the color a touch. Thanks
trav26 is offline
Old 05-28-2012, 10:12 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: How To Lighten Grey Mortar Color
Lots of options here, White mortar being probably the easiest. Add some lime would make it whiter. White sand or silica sand will help out.
More yellow or brown sand really won't help much. A dash of portland might help, but don't over do it.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 05-28-2012, 10:20 PM   #3
trav26's Avatar
Thanks a lot. I wasnt sure if adding more portland white would throw off the mixture in a negative way. Ill mix up a sample tomorrow.
trav26 is offline
Old 05-28-2012, 11:00 PM   #4
dakzaag's Avatar
Trade: mason
Rewards Points: 786
If you get it too rich, it will get brittle. I would try to find white sand first off then white mortar or lime. Lime really makes it white. probably too white, but you can play with it some.
D K & Sons
dakzaag is offline
Old 05-28-2012, 11:18 PM   #5
trav26's Avatar
I have already looked for white sand locally and have not had any luck. I dont need to lighten up too much so hopefully i can get away with a touch of white portland.
trav26 is offline
Old 05-29-2012, 08:13 AM   #6
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,344
Try to find white type S mortar...that would make it more simple than getting your portland/lime ratios right if you are not familiar with mortar mix design.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 05-29-2012, 10:09 AM   #7
Mad Italian
TheItalian204's Avatar
Trade: Licensed Mason/Owner of small business
Rewards Points: 2,004
Send a message via Skype™ to TheItalian204
acrylic hues.
www.gabesmasonry.ca
Originally Posted by Mud Master View Post
I hate when a profitable job becomes a charitable write off.
TheItalian204 is offline
Old 05-29-2012, 04:05 PM   #8
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
As stonecutter said, get some federal white type S or N and substitute a bit for the grey cement.
www.dominionmasonry.ca
dom-mas is offline
Old 05-29-2012, 07:43 PM   #9
JBM's Avatar
Trade: Masonry
Rewards Points: 3,494
Dragon light dries light tan-ish if you can find it and use tan sand.
JBM is offline
Old 05-29-2012, 08:33 PM   #10
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Yeah, start with light and then darken it, much easier than starting dark and trying to lighten.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 05-30-2012, 12:37 AM   #11
Tscarborough's Avatar
Rewards Points: 1,392
If you put acrylic pigment into your mortar, you are a handyman at best.
Edit
That is not quite true. White pigment is titanium dioxide so it is acceptable, but not the most effective way to lighten mortar.
Tscarborough is offline
Pointing color (lighten up color) Pheasant89 Masonry 17 04-13-2011 08:06 AM
Mixing dirt in mortar for color? bisp21 Masonry 4 08-13-2009 12:23 PM
Changing mortar color? kcrossley Masonry 1 12-17-2006 01:44 AM
