How To Anchor Sandstone Wall Panels
Old 09-02-2009, 12:06 PM   #1
PMKColorado's Avatar
Trade: Masonry & Stucco
1 1/2" minus sandstone; 2'x4' panels; 17 lbs +/- SF. Design specifications; use adjustable masonry ties set in mortar bed. Steel frame structure, Gyp sheathing, one story; all panels bear on footer or lintels. My concern; stone will likely be 1 1/4" - 1 1/2" thick, plus 1" gap; not leaving much of a mortar bed or room for the ties (1 3/4" +/-). Is this design sufficient to hold the panels? Suggestions without adding to installation costs? I could use split ties if they are available 1 3/4" leg, ...help before I RFI engineer...
PMKColorado is offline
Old 09-02-2009, 03:04 PM   #2
Tscarborough's Avatar
Re: How To Anchor Sandstone Wall Panels
That is the correct system (with split leg or pins), but I have never seen it done at less than 2-1/2" (limestone). That is getting very close to an adheered system weight, and there is no way in the world I would do it as specified without a 100% wavier of responsability from the structural engineer.
Tscarborough is offline
Old 09-02-2009, 05:39 PM   #3
artisanstone's Avatar
Trade: Stonemasonry
Laticrete has an epoxy that is supposed to be able to anchor a 1.75" veneer. It's applied to the back of the stone in spots, so drainage is maintained. They say no mechanical fasteners necessary. I don't know about your backup though, I think they spec cement board. It's worth a look.
artisanstone is online now
Railroad Tie Retaining Wall Question SDFConstruction Landscaping 17 03-23-2010 08:42 AM
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 09:52 PM
CMU wall repair mcgyverdc Masonry 6 12-04-2008 04:48 PM
Plaster applied to interior of interior wall problems CMU General Discussion 1 10-14-2008 10:37 AM
Reinforced Polystyrene Wall Panels bobby1968 General Discussion 4 02-21-2008 10:25 PM
